opinions on underdrive crank pulleys
Rich
Why would you want a slower running water pump, altenator and PAS pump?
sorry just used the search facility(what I should have done in the first place)
found plenty of interesting info to put me off the UR racing crank pulley.
will go for a BL one due to the damping and as you say slower running accessories
The whole point of getting an underdrive pulley is to specifically slow down the accessories, and thus 'save power', i.e. less parasitic drag on the engine :)
I had one once, noticed no great difference, got scared of my crank snapping, went back to the stocker, noticed no great difference except I could sleep at night again ;)
-Ian
I am fairly sure it is only the crank pulley that is slightly smaller. The rest of the pulleys are normal size.
Yeah but the crank pulley drives the belt so a smaller pulley makes everything that is driven by the belt run slower.
I know, but still - sod that!
