lockys96 Posted December 2, 2006 Share Posted December 2, 2006 i look forward to seeing what mpg gains i get from this. i soaked the nuts in some wd40 before i had a go at them, dont want to start shearing stuff off. it came out rather easy apart from the tight space you have to move in there. you need a long 12mm socket and racket, i took the plastic filter pipe off to gain better access. now the old one looked very tired and black. will post results when i go through another £30 of fuel i have been getting 140miles on £30 before, will see how it goes:) Link to comment Share on other sites More sharing options...
silvershark44 Posted December 2, 2006 Share Posted December 2, 2006 £140 to a full tank! That is bad, the worst ive had is about 200 miles. I look forward to hearing about any success though! Link to comment Share on other sites More sharing options...
lockys96 Posted December 2, 2006 Author Share Posted December 2, 2006 i did say for £30 of fuel lad Link to comment Share on other sites More sharing options...
lockys96 Posted December 2, 2006 Author Share Posted December 2, 2006 and i dont have a tank to take £140 worth of fuel unless its that new 102 ron stuff from bp which is like £2.49 per litre Link to comment Share on other sites More sharing options...
SoundWave Posted December 2, 2006 Share Posted December 2, 2006 Nice one locky. I'd be very interested to know the difference it makes. Link to comment Share on other sites More sharing options...
lockys96 Posted December 2, 2006 Author Share Posted December 2, 2006 sure andy, i thought you would like to know Link to comment Share on other sites More sharing options...
SoundWave Posted December 2, 2006 Share Posted December 2, 2006 yeh mate, anything that might get the fuel bills lower (without putting a brick under the accelerator) can't be bad! Link to comment Share on other sites More sharing options...
silvershark44 Posted December 2, 2006 Share Posted December 2, 2006 and i dont have a tank to take £140 worth of fuel unless its that new 102 ron stuff from bp which is like £2.49 per litre u know what i meant 140 miles Link to comment Share on other sites More sharing options...
RobSheffield Posted December 2, 2006 Share Posted December 2, 2006 u know what i meant 140 miles Still, its not 140 miles to a tank, its 140 miles to £30, which is around a half a tank. Link to comment Share on other sites More sharing options...
bungy Posted December 2, 2006 Share Posted December 2, 2006 How long did it take to change your sensor and how would you rate it in difficulty ie. 1 spanner easy and 5 spanners hard. Link to comment Share on other sites More sharing options...
Jake Posted December 2, 2006 Share Posted December 2, 2006 How long did it take to change your sensor and how would you rate it in difficulty ie. 1 spanner easy and 5 spanners hard.It's a five minute job. 2 nuts and one electrical connector to undo. Only thing is the engine needs to be stone cold else you will burn yourself. Link to comment Share on other sites More sharing options...
lockys96 Posted December 2, 2006 Author Share Posted December 2, 2006 rating is a 2spanner job. as its hard to get the spanner in there.plus you should remove the filter pipe and one of the clips was a pain to get out on the 02 sensor loom. so i cut it with some snips, as its all replaced by the new loom. will post results soon Link to comment Share on other sites More sharing options...
GazzaGSi Posted December 4, 2006 Share Posted December 4, 2006 Do you need to reset the ECU once changed? How's the economy now? Is it better? Link to comment Share on other sites More sharing options...
DamanC Posted December 4, 2006 Share Posted December 4, 2006 Well i had a go at mine this afternoon...............i couldnt get the bolts off. Garage job for me! Link to comment Share on other sites More sharing options...
lockys96 Posted December 4, 2006 Author Share Posted December 4, 2006 Do you need to reset the ECU once changed? How's the economy now? Is it better? dont know yet. and perhaps i should reset the ecu, but id have thought with the new sensor in place it would work straight away. someone tell me otherwise:d Link to comment Share on other sites More sharing options...
Nic Posted December 4, 2006 Share Posted December 4, 2006 dont know yet. and perhaps i should reset the ecu, but id have thought with the new sensor in place it would work straight away. someone tell me otherwise:d I remember reading that the ECU goes into (rich) default mode when it doesn't receive a good signal from the O2 sensor, which is the cause of the poor fuel economy. It can't do any harm resetting it. Link to comment Share on other sites More sharing options...
lockys96 Posted December 4, 2006 Author Share Posted December 4, 2006 is it just remove the battery and reconnect? Link to comment Share on other sites More sharing options...
supRo Posted December 4, 2006 Share Posted December 4, 2006 is it just remove the battery and reconnect? You just need to pull out the two green EFI fuses (30amp) for 2 mins On my car I saw the benefits straight away! Car was much more economical! Link to comment Share on other sites More sharing options...
GazzaGSi Posted December 4, 2006 Share Posted December 4, 2006 dont know yet. Sorry, it was 2 days and the £30 would of been gone in mine lol Maybe my o2 sensor is abit tired...? Link to comment Share on other sites More sharing options...
lockys96 Posted December 4, 2006 Author Share Posted December 4, 2006 lol, true Link to comment Share on other sites More sharing options...
lockys96 Posted December 5, 2006 Author Share Posted December 5, 2006 Well just to add, i reset my ecu yesterday. the car feels amazingly smooth now, cant believe it. plus i doubt ill be saving too much cash, as the car seems boosty and on song. id recomend changing it to anyone Link to comment Share on other sites More sharing options...
Nic Posted December 5, 2006 Share Posted December 5, 2006 Well just to add, i reset my ecu yesterday. the car feels amazingly smooth now, cant believe it. plus i doubt ill be saving too much cash, as the car seems boosty and on song. id recomend changing it to anyone I'm pleased to hear it's made a noticeable difference Si Link to comment Share on other sites More sharing options...
lockys96 Posted December 5, 2006 Author Share Posted December 5, 2006 i will post some pics of the old ones condition later. it was black. i remember when i had my old dyno and it showed my car was throwing fuel in as the second tubbie was coming on. a bit too much. wonder if ive got some ponies back now feels like a big fat luxury car, with boost Link to comment Share on other sites More sharing options...
GazzaGSi Posted December 8, 2006 Share Posted December 8, 2006 Sorry to drag this up again, just wanted to say thanks for reporting back the info, ive not had net access for afew days to check Think mines due for renewal Cheers Link to comment Share on other sites More sharing options...
Nic Posted December 8, 2006 Share Posted December 8, 2006 Think mines due for renewal Give me a shout Gaz if you want prices for a new O2 sensor Link to comment Share on other sites More sharing options...
