JohnA Posted December 1, 2006 Share Posted December 1, 2006 In the process of troubleshooting electrical gremlins (most likely due to the UKSpec sham of an alarm) I connected the positive of the digital multimeter to the battery and the negative on to: 1. radiator top (plastic) 0V 2. coolant inside 11V 3. coolant expansion tank (plastic) 0V 4. coolant inside the tank 3-3.5V 5. metal parts of the engine 12.4V, same as the battery at the time. These coolant values do look a bit too high to me:blink: . The coolant is just over a year old, so no deposits and such. It shouldn't be so conductive FFS. Has anyone got similar values from their car? I know it's not done usually, but it's dead easy to check. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 1, 2006 Share Posted December 1, 2006 You bored or something John? Let's all run a Geiger counter over the engine too, and post up the results Coolant with A/F in it IS quite conductive, a lot of low coolant level sensors work that way. Link to comment Share on other sites More sharing options...
JohnA Posted December 1, 2006 Author Share Posted December 1, 2006 No Chris, but recently I'm getting a dry 'click' first time when I try to start the engine, and I'm scared that something is draining the battery (which got totally empty last time it was left unused for 2 weeks) Chris, if those readings are OK then fair enough. That voltage is much lower on other cars though. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 1, 2006 Share Posted December 1, 2006 How much current draw at rest is the battery seeing? I soometimes get cars with lots of "gizmos" in that are pulling silly current from the battery even when everything is supposedly off. Alarms sometimes seem to be a common denominator, but the alarm experts seem to decry that theory. All I can say is most of these problems start when a factory stock car has "things" nailed onto the electrical system Link to comment Share on other sites More sharing options...
Marty Posted December 1, 2006 Share Posted December 1, 2006 If its water based it will be conductive? It'd be more than likely a alarm draining your battery to that extent i wouldve thought, mine will do the same thing if i leave my car standing too long. Either that, or maybe your battery is on its way out ? Not much help am i Link to comment Share on other sites More sharing options...
JohnA Posted December 1, 2006 Author Share Posted December 1, 2006 How much current draw at rest is the battery seeing? Can't remember now, I had checked it months ago and it was 'too much', a good fraction of an Amp I think. I had measured it by disconnecting the battery and fitting the DMM in series in 'Current mode' The alarm had a fit, and the ECU reset along with the trip meter etc, so I try to avoid disconnecting the battery if I can. The altenator provides proper voltage and the battery is less than 2 years old. ...most of these problems start when a factory stock car has "things" nailed onto the electrical system Probably not the case here, I am king of stock in case you've missed it. I go to great lengths before changing something away from stock - it needs to make a good case, and the vast majority of aftermarket offerings are overpriced substandard tat in my lonely view. Link to comment Share on other sites More sharing options...
Kev.O Posted December 1, 2006 Share Posted December 1, 2006 No Chris, but recently I'm getting a dry 'click' first time when I try to start the engine, and I'm scared that something is draining the battery (which got totally empty last time it was left unused for 2 weeks) Chris, if those readings are OK then fair enough. That voltage is much lower on other cars though. If I leave my car for two weeks the battery is flat and I don't have any after market goodies Link to comment Share on other sites More sharing options...
JohnA Posted December 1, 2006 Author Share Posted December 1, 2006 I see yours is UKSpec as well. We're not the only ones you know, there must be a fault, something that ages badly and leads to excessive current draw, even when the alarm is not used. You can't leave this car for a week or two and expect to start it again. It sucks. Link to comment Share on other sites More sharing options...
fredm Posted December 4, 2006 Share Posted December 4, 2006 I have heard that you can use "conductivity" measured with a dmm to give you an idea as to how well your antifreeze is performing, I'm not sure what readings would be classed as good or bad though. I have a feeling it's not too accurate though. I suspect you will agree that the prefered method is a Refractometer. But anyway, I thought I'd post up my results for your interest. Positive dmm probe onto battery + Negative dmm probe into Rad coolant 12.35v ########### into Expansion Tank 9.5v ###########onto cylinder head 12.35 Interestingly if you connect Negative dmm probe to battery -ve and then probe rad coolant with +ve probe I got 0.3v Cold engine,not used for a week. Coolant, Toyota oem 3 months old. As for the parasitic drain on the battery, with a dmm set to dc amps placed in series with the -ve battery terminal and -ve lead I have 0.03amps drain. My car is standard with no gizmo's fitted, the oem alarm/immobiliser has been binned, no remote locking for me. I have left my car for 3 weeks and it starts like it was last used the day before. My previous 94 UK could also be left for a fortnight with no problems, that too had the standard immobiliser/alarm disconnected. As you say you must have a drain somewhere. Happy hunting! Link to comment Share on other sites More sharing options...
JohnA Posted December 4, 2006 Author Share Posted December 4, 2006 I have heard that you can use "conductivity" measured with a dmm to give you an idea as to how well your antifreeze is performing, ... Thanks for the feedback mate. You are right, connecting (-) to the block and (+) in the coolant you get an idea of the conductivity of the coolant. The more tired it is, the more conductive it gets - supporting the creation of electrolytic deposits all over the coolant channels. Below 0.3V is good, 0.5V or over means that the coolant needs urgent flushing. That's what I should have measured in the first place, but I had a few glasses of wine and couldn't think straight:blink: Because there was no interest in the thread I didn't bother coming back to rectify it. I'm almost certain it's the UK Alarm responsible for the drain, it's been doing it since I got the car, now it may have got worse though. Link to comment Share on other sites More sharing options...
