jamesmark Posted December 1, 2006 Share Posted December 1, 2006 I went full decat tonight with 1.2 rest ring, all fine and very pleased with first drive of it gave it some over the space of about 5 miles and then a nice calm drive to drop of my mate all fine and no issues big smile on my face. Coming back from my mates I gave it some fast pace on kickdown to see what boost I was pulling just under 1 bar, it then started to rain so eased off, a few miles after this the engine warning light came on I must have been traveling at appx 55 mph and the engine is very very lumpy and wants to die on me, when i put the foot down it wants to die on me, i pulled over and then it went off but started again on just idle. switched her off and waited and then started up again and all fine went appx 1 mile on it came again with engine wanting to die on me so I limped home but on the way home it woudl right itself and i had my car back for maybe a mile then it would start again. is it FCD? but remember I had no trouble when i was putting the car through it paces for appx 5 miles (consited of straights and bends. FCD was fitted 4 days ago and no issues yet. or EGT that plugs into 2nd cat this has no where to go what am i meant to do with this? as the CW decat i have does not support an egt sensor, can this be unpluged? and how? Oh and it used an large amount of fuel over i would say 40 miles max nearly 1/4 tank Quote Link to comment Share on other sites More sharing options...
Jake Posted December 1, 2006 Share Posted December 1, 2006 Which warning lights exactly? Have you checked for stored error codes? If not, do so. When you say EGT do you mean the Cat Temp probe? If so just tie/cable tie it out of the way. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted December 1, 2006 Share Posted December 1, 2006 My money is on the FCD, disconnect it from the ECU and join the TPS signal wire as it was before and give that a go. Quote Link to comment Share on other sites More sharing options...
Homer Posted December 1, 2006 Share Posted December 1, 2006 It could also be knackered plugs. What plugs did you install after going BPU and what did you gap them too (if at all). I killed a set of IK22's in les than 2 miles of raising the boost way past their limit. Edit - as Jake said, check for the ECU error code before you do anything else. Quote Link to comment Share on other sites More sharing options...
RedM Posted December 1, 2006 Share Posted December 1, 2006 I thought spark plugs too. I'm not a techie though but maybe the forum is having an effect on me. Hope you get it sorted, Mark. Quote Link to comment Share on other sites More sharing options...
secondjump Posted December 1, 2006 Share Posted December 1, 2006 Check your ecu connection - it may have been knocked whilst fitting your fcd. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 Sorry for the first post as was really tired when I finally crawled home, I will check the error codes tonight. I have IK24's in brand new from Mkivstore, erm Gapping?? no idea on that I just put them in and made sure they were not loose. The warning lights were the engine one (I think) which on the right hand side cluster the very first one and the red triangle. With reconnecting the TPS wire will I not hit fuel cut a lot easier? I dunno if this maybe anything to do with it I bought a 1.2 bar RR the whole has a diameter of 2.2 inch roughly. As before the car comes back to me from time to time and then I loose everything, when I had the loose connections at the top of the coil packs the engine was smoother than what it is now. It is like very very bad kangaroo gas as if the car is ready to stall when you press the acc pedal. Thanks guys, if I do not get this sorted tonight then thats the trip to Scotland to see my parents off should have bloody waited. Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 1, 2006 Share Posted December 1, 2006 gutted mate. hope you get it sorted out soon. Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 1, 2006 Share Posted December 1, 2006 James, if you have a check engine light coming on then your first step is to read off the error codes and let us know what they are Saves a lot of flailing and guesswork. -Ian Quote Link to comment Share on other sites More sharing options...
Angarak Posted December 1, 2006 Share Posted December 1, 2006 It could also be knackered plugs. What plugs did you install after going BPU and what did you gap them too (if at all). Do dodgy plugs cause the MIL light to come on? Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 James, if you have a check engine light coming on then your first step is to read off the error codes and let us know what they are Saves a lot of flailing and guesswork. -Ian Cheers Ian I will do tonight when I get home. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 Oh and I forgot to mention the Kakimoto exhaust sounds amazing on full decat, at least thats something. Quote Link to comment Share on other sites More sharing options...
chilli Posted December 1, 2006 Share Posted December 1, 2006 or EGT that plugs into 2nd cat this has no where to go what am i meant to do with this? as the CW decat i have does not support an egt sensor, can this be unpluged? and how? Well it won't be this, normally this is just cable tied up out of the way in case you revert back to stock - it won't cause any adverse affects... I'd check plugs and sensors first, the error code will get you started... it used a lot of fuel? so what did you expect? Quote Link to comment Share on other sites More sharing options...
Jake Posted December 1, 2006 Share Posted December 1, 2006 it used a lot of fuel? so what did you expect? Are you forgetting JamesMark's heritage? Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 1, 2006 Share Posted December 1, 2006 Are you forgetting JamesMark's heritage? ooooooh, the cheek of it Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 it used a lot of fuel? so what did you expect? I know the supra uses a lot of fuel and that does not concern me but to travel 45 miles (if that) it has never in the time I have had it used that amount as what it did lastnight, that was what the comment was about and to possible try and iron out possible causes maybe? Quote Link to comment Share on other sites More sharing options...
chilli Posted December 1, 2006 Share Posted December 1, 2006 ok I get ya lol well could it be something to do with the o2 sensor, maybe you killed it and it is overfueling when running in closed loop now? Quote Link to comment Share on other sites More sharing options...
8secSupra Posted December 1, 2006 Share Posted December 1, 2006 I assume your still running on the stock SM intercooler, and this is a UK car with the MAF. Spark plugs wont cause this. You've most likely blown an intercooler pipe. The first one to go is usually down from the throttle body by the battery. I've seen it happen dozens of time, as soon as you turn up the boost those stock hoses can give way. Check all your IC hoses and find the split or separation. This will cause the MIL light to come on because the car will run super-rich with a leak after the MAF meter (blown IC pipe). You will use a ton of fuel and the car will hardly idle on its own. Thanks, Quote Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2006 Share Posted December 1, 2006 I assume your still running on the stock SM intercooler, and this is a UK car with the MAF. J-spec (MAP) according to his sig. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted December 1, 2006 Share Posted December 1, 2006 FCD almost everytime. Who wired it? Quote Link to comment Share on other sites More sharing options...
8secSupra Posted December 1, 2006 Share Posted December 1, 2006 J-spec (MAP) according to his sig. Sounds like the ECU is in limp mode then (CALPAK). Normally caused by detonation picked up by the knock sensors, a faulty primary sensor (TPS, MAP, or O2 sensor), or by hitting fuel cut-off. If the FCD is bad, it may not allow the MAP signal to pass, and can also cause this. In the US, the first thing we check is the IC pipes! Thanks, Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 Done the error code check and it pulled up error code 43, what could this be any ideas? going to do a search too but any help would be great http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13923&d=1112558346 Quote Link to comment Share on other sites More sharing options...
Homer Posted December 1, 2006 Share Posted December 1, 2006 Are you sure its 43 and not 34? 34 would be more likely as it indicates a pressure problem which would be in line with a blown IC pipe ( at least I think!) Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 1, 2006 Author Share Posted December 1, 2006 Shit, and I have reset the ecu, I had one flash then 4 flashes and then 3 flashes and the one flash hen a long pause. This was with ignition on. Damn I am going to have to get the car to do it again. Quote Link to comment Share on other sites More sharing options...
squiffy Posted December 1, 2006 Share Posted December 1, 2006 after i decatted with an fcd my old plugs lasted a couple of days before i had to replace them Quote Link to comment Share on other sites More sharing options...
