Lee Posted May 19, 2004 Share Posted May 19, 2004 Have had my supra now for 4 months with no major problems, with the better weather coming in i'm starting to use the car to it's potential! But i'm noticing that 1. The second turbo doesn't "kick in" now and again. When this happens i let off the throttle and try again and seems to work fine. 2. The revs limits to 5750 rpm sometimes. Have reset the ECU tonight but no joy...any ideas anyone? Thanks in advance Specs Jap import, Auto TT 94 Standard apart from Hks BOV and induction kit P.s sorry if its a bit vague...first technical post! Still learning Quote Link to comment Share on other sites More sharing options...
TLicense Posted May 20, 2004 Share Posted May 20, 2004 Lee, Problem number 1 seems to be a bit of a recurring problem with these cars. Especially as they tend to age. My personal belief is that the hoses to the valves that control the 2nd turbo go hard and brittle. I changed all of these hoses and did them up with jubilee clips and I haven't sufered with it since. Problem number 2 sounds very perculiar, and it's the first time I've heard of anyone suffering with anything like this. What has your car got in terms of speed convertor/ speed limit defensor? I'm sure it's nothing to do with this, as it's related to engine rpm not vehicle speed. but maybe worth a little investigation just to rule it out. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 20, 2004 Share Posted May 20, 2004 I used to have a random rev limit in first, and only in first, gear. It would cut in between 5800 and 7200 rpm Is it as random as that? As for the second turbo, it's hoses hoses hoses my friend There are lots to check, so are rather inaccessible. -Ian Quote Link to comment Share on other sites More sharing options...
Alex Posted May 20, 2004 Share Posted May 20, 2004 Is it deffo a rev limit and not a fuel cut? (are you sure the cats are in place?) If it's a rev limit could it be down to the speed de-limiter? Which type have you got? Quote Link to comment Share on other sites More sharing options...
Lee Posted May 20, 2004 Author Share Posted May 20, 2004 Thanks for the responses! Not sure on the type of speed convertor/ speed limit defensor type but i phoned the importer today and they said it's a "cheap all in one" at around £130. There is a dearer option of £300. They've told me to bring it down, possibly engine management they said. Not convinced though as no warning lights are showing. I'm not "deffo" on whether it is a rev limit of fuel cut. How can i tell? Not sure if the cats are in place either. Will get someone to check this out promto! And yes the revs cut between 5800 and 7200 rpm. But this happens in all gears even neutral. Quote Link to comment Share on other sites More sharing options...
