quick boost gauge question??
Jim_1979
Surely you can use the wiring from the clock loom (if putting a 52mm gauge in) ? Because there will be a live, earth and illumination wire, right??
If so, anyone know what's what there? Could easily take it from the stereo feed etc... but just thought might as well take it from the clock.
ta
You can use the grommet where the clutch cable would normally pass through the firewall - its just to the back of the turbo's - poke the pike through there from the engine side and you can then reach under the dash and feed it up to the clock. I used a rubber hose, which wasnt as 'floppy' as a silicone one.
You dont need to remove the clocks etc. Just remove the dash trim around the auto lever, the small bit of trim with the hazards on and the heater trim. You can then feed up the pipework from under the dash by the steering wheel.
To get good solder connections though, your best pulling the connectors and removing the trim out of the way.
