JamieP Posted November 28, 2006 Share Posted November 28, 2006 Just been reading up on the AEM forum and a thread got me thinking will i need a resistor pack with Hks 1000cc injectors? regards jamie:) Quote Link to comment Share on other sites More sharing options...
Dragonball Posted November 28, 2006 Share Posted November 28, 2006 Hi or Lo impedance m8? Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 28, 2006 Author Share Posted November 28, 2006 I dunno.. how do i tell? i got them from Nic maybe he would know. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 28, 2006 Share Posted November 28, 2006 Yes Quote Link to comment Share on other sites More sharing options...
Lucifer Posted November 28, 2006 Share Posted November 28, 2006 Resistor pack LOL IF you want your AEM to run at a crappy resolution you would. Personally i'd ask your tuner ............. ok ok ok ok Ill tell you - Go buy the AEM injector driver. Quote Link to comment Share on other sites More sharing options...
JamieP Posted November 28, 2006 Author Share Posted November 28, 2006 Thanks Terry. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 28, 2006 Share Posted November 28, 2006 Yes they are low impedance, so as Terry said, you'll need a resistor pack. This is the part number for the resistor pack used on the UK Spec Supra: 28510-46020 Resistor Pack Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 28, 2006 Share Posted November 28, 2006 Isn't the AEM injector driver, mmm, a resistor pack? -Ian Quote Link to comment Share on other sites More sharing options...
TLicense Posted November 28, 2006 Share Posted November 28, 2006 I asked this very question a week or two ago on the AEM forum. What would happen if someone was to run a low impedance injector with the AEM with no resistor pack? Here's the reply:- Typically what happens when you run low impedance injectors without the resistor pack is that the injector drivers inside the ECU will turn themselves off when they get too hot from excessive current - over 1.5 amps continuous in most cases. As far as how the engine runs, it will act like a boost cut when the injectors pull too much current causing the drivers to turn off. Increasing injector open times mean more current draw and that's why it acts kinda like a boost cut. The injector drivers inside the EMS can possibly be damaged but most of the time they are OK once they cool off and are run with a resistor pack or high impedance injectors. Quote Link to comment Share on other sites More sharing options...
