PC upgrade time - suggestions welcomed
Animal
My PC is due an upgrade and I'm after some recommendations from the more knowledgeable folks around here.
My band rehearse in my flat and I've managed to volunteer my PC to be set-up as a recording studio (currently downloading Cubase) so I'd like some advice on what sort of upgrades I should consider.
I'm currently running:
AD77 Infinity motherboard
AMD 2800 Athlon
2Gb DDR RAM
Nvidia GeForce 5600 (youngest thing in my PC at 2-3 years old - everything else being over 4 years)
Unknown cheap & nasty soundcard (which died last month and refuses to accept any drivers)
So far I've seen a 3400+ Athlon 64 x2 with a Creative X-Fi soundcard. No idea about motherboards.
I'm expecting to spend maybe 300-500 quid. What would people recommend (and can anyone get any good deals?)
Cheers
Animal
  • Replies 64
Ok first of it depends on what you want to use your PC for. I would recomend Dual core, AMD are better and running grunty single aplications (ie games etc) where as Intel core duo seems better at running a number of applications. 1gb of RAM is the min you want on a system and the X-Fi card would be good if your planing on band stuff. Motherboards are not so important these days unless your planning on overclocking your cpu or gfx card.
if your looking to use the pc for lots of music work i would recommend a soundcard which is designed for the cause, creative are a bit mainstream and not so specialised, i cant think of the brand atm, but i will ask my mate later who does his own music production.
As for spec's i would recommend some sort of duel core for a nice setup in a music studio.
Core 2 Duo, 2GB memory, graphics card I'm guessing not too important unless you want to be running the latest games in highest detail. I recently got a NVidia 7600GT and while I couldn't run stuff in highest detail at 1920x1200, my monitor doesn't go up that high anyway :D
I've always stuck with NVidia cards as they tend to have better drivers/performance with Linux.
Probably E-MU or M-Audio? Both do some good audiophile stuff, M-Audio probably at the cheaper end.
http://www.emu.com/products/welcome.asp?category=505
http://www.m-audio.com/index.php?do=products.list&ID=pciinterfaces
I've just gone Core 2 from a long line of AMD processors.
It's very overclockable, 2.13 to 3Ghz reliably :)
I've got an Abit AB9 Pro board, decent RAM. Even got OS-X working on it yesterday (which was a hard slog, but worth it).
AMD will be releasing something interesting in the new year - there's never a right time.
Ok here we go rough idea of what you are looking at for £500 bucks
First off if you go for the latest tech (ie the AM2 chip set)
Asus M2N4-SLI motherboard £68
AMD AM2 X2 4200+ £133
Geil 1gb PC6400 DDR2 800mhz RAM £99
Leadtek 7600GS Silent Running Gfx Card £75
Leaving £125 for a sound studio sound card
If you went for the older 939 socket board
Asus A8N-SLI £54
AMD X2 4600 £163
OCUK 1Gb 3200 400mhz RAM £76
Leaving £132 for the sound card.
Personally I would go for an AM2 board as the RAM will run much faster and so will do more, plus the upgrading is much better as you wont need a new motherboard etc. I have chosen SLI boards as again if you need more graphics power then you can always add another card. I went for the Asus boards as A) They tend to be very very good and well built B) their after customer care is awesome and C) They tend to get very good reviews, infact I do believe that Custom PC still says that the A8N is still the best Skt 939 board on the market.
If you need any help let me know, I would offer to set it up for you but no doubt your probably miles away from us country bumpkins
Oh I am board at work ok.
Cheers dude, your first option sounds good, maybe 2Gb RAM and could I keep my existing GFX card? The M-Aidio Delta 44 is tempting as it looks to have separate inputs for each instrument. My guitarist it the audio tech of the band and was looking at taking the outputs from each channel of the mixing desk into my PC a 4 separate tracks for editing.
OCUK scare me...toom any bad reports...
I got my gear from dabs and ebuyer this month and it all rocks/works :D
I spent about 1k though :( C2D 4 the win :D ....it benchmarked 3x faster than my old P4 2.5ghz rig :D No OC'ing.
Find intel overpriced and not very good at running the programs I use my PC for. My pc benchmarks at 8000 at the mo on 3Dmark06
Well that used to be the case... but IMO C2D beats the pants off AMD's dual core line up... Of course that will no doubt swing back the other way next year.
