Guest laz Posted November 26, 2006 Share Posted November 26, 2006 hi all...i got a n/a supra and my mate handed me a K&N filter the other day and the neck size is 100mm.....so i was thinking!! what if i re piped the intake with 100mm tube all the way to the throttle body this has got to give less restriction than the stock air box with its 80 mm tube.....i know how people feel about cone filters round here , but i think this has got to work better!! what do you all think laz 94 n/a blue ss exhaust 18" splitrims Quote Link to comment Share on other sites More sharing options...
Nic Posted November 27, 2006 Share Posted November 27, 2006 Stick with the stock airbox, it is not restrictive, has 2 cool air feeds and has bigger/better filtration. The only thing you'll gain by fitting an induction kit is noise. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 27, 2006 Share Posted November 27, 2006 Also, the MAF would still be 80mm and unless you want to run an aftermarket ECU and new 100mm MAF it's not going to work. Quote Link to comment Share on other sites More sharing options...
bromy Posted November 27, 2006 Share Posted November 27, 2006 Alex, there is no MAF on the jap n/a only the US version has MAF, japs are MAP Quote Link to comment Share on other sites More sharing options...
Alex Posted November 27, 2006 Share Posted November 27, 2006 Alex, there is no MAF on the jap n/a only the US version has MAF, japs are MAP Whoops apologies. Bah...bl00dy Toyota putting different systems all over the place Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 27, 2006 Share Posted November 27, 2006 If you want to ruin the pulse tuned length and kill performance, do it. If you want it to work properly leave all the induction alone. Quote Link to comment Share on other sites More sharing options...
Guest laz Posted November 27, 2006 Share Posted November 27, 2006 ok thanks.... would any body be able to recomend where i can get a de-cat pipe (the first one from engine) where its not gonna cost a fortune, £150 for an 18" bit of tube is a bit crazy laz Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 27, 2006 Share Posted November 27, 2006 It's not just an 18 inch bit of tube, it's a jig made dual downpipe, with stainless flexi section made of dual concentric pipes, two ground flanges, with fish tailed swaged joints.... 150 is cheap, go try and make one They are a tricky bugger to fabricate. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted November 27, 2006 Share Posted November 27, 2006 That's telling you! Quote Link to comment Share on other sites More sharing options...
Terminator Posted November 27, 2006 Share Posted November 27, 2006 You are on form today Chris. Quote Link to comment Share on other sites More sharing options...
Guest laz Posted November 27, 2006 Share Posted November 27, 2006 i think i`ve been told aswell!! ....i suppose i can wait till it breaks up inside then shake all the bits out the end....he he free de-cat Quote Link to comment Share on other sites More sharing options...
