Supradude666 Posted May 17, 2004 Share Posted May 17, 2004 Hey guys, a few things first of all i got a leaky sump (the sealant has corroded and is leaking) and as my beastie is due another oil change i thought id get it done now and an oil change at the same time problem solved BUT and heres the thing i was told that using castrol GTX magnatec isnt good on a supra due to Toyota's small tolerances (is this bull shit) so what oil would be best i got the grade right 5w30 but what make???? thanks for your input guys.. secondly what is the PCD and the Offset of our cars DUmmy here cant find it anywhere lol.. im asking because i need to know if the wheelz im gonna borrow from daddy are gonna fit while my spangly 18's are off for a polish and general tidy up got a bit tatty over the harsh winter wanna spruce em up a bit... thanks for the info guys Quote Link to comment Share on other sites More sharing options...
matt Posted May 17, 2004 Share Posted May 17, 2004 PCD is 114.3 with 50 et. Fit depends on wether or not you have UK brakes..... I use mobil1 motorsport which IIRC is 10w50.... theres a thread discussing magnatec somewhere.. Quote Link to comment Share on other sites More sharing options...
Supradude666 Posted May 17, 2004 Author Share Posted May 17, 2004 cheers mat thats justr what i wanted to know.. Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted May 17, 2004 Share Posted May 17, 2004 You will also need to take into consideration the hub center bore size (60.1mm). Quote Link to comment Share on other sites More sharing options...
