Paul R Posted May 17, 2004 Share Posted May 17, 2004 Hi, I finally got the last and remaining Cat off today!! woohoo!! I picked it up from CW's today and drove it back. It has definately made a big difference. There is almost no lag from the first/second turbo and it pulls much much stronger. It only made 1.0 bar in the day though (when it was hot) and about 1.1 bar when it was a bit cooler. Is this normal? I was hoping for 1.2 bar?? I have cheap NGK plugs with a gap of 0.8mm at the moment. Will I see an increase if I get some colder grade plugs in there? So what does that make my car? as in BPU or BPU+?? It has, HKS type S Intercooler GReady Oil Cooler K&N induction kit Both cats out and an FCD RSR exhaust HKS SSQV Possibly hybrids but We arent sure on that one! - dunno how to find out! Paul. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 17, 2004 Share Posted May 17, 2004 No way of telling without taking them apart Sounds like you are enjoying it though! Plugs will not increase boost - only allow improved pickup Quote Link to comment Share on other sites More sharing options...
baldy Posted May 18, 2004 Share Posted May 18, 2004 u dont list a fuel pump! im running 1.45 bar boost,but have walboro pump & fse valve,&still on 440's Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 18, 2004 Share Posted May 18, 2004 If you must know, your now BPU+ (the plus being the IC/oil cooler). Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 18, 2004 Share Posted May 18, 2004 Originally posted by baldy u dont list a fuel pump! im running 1.45 bar boost,but have walboro pump & fse valve,&still on 440's Paul - have a check in your petrol tank and see what pump you have there I am sure that the fuelling really contributed to the downfall of my turbos due to lean running at higher boosts and increased EGT's as a result I have the FSE and pumps here! Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 18, 2004 Share Posted May 18, 2004 What were your AFRs when you got your car tested at THOR Paul? Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted May 18, 2004 Share Posted May 18, 2004 Sounds good Paul....... What time did you pick it up ? Was going to go tho the Bhurtpore inn for some beers, but the cab from the swan wanted £25 each way! So in the end we just stayed in the swan.... See the BMW outside Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 18, 2004 Share Posted May 18, 2004 Originally posted by Syed Shah What were your AFRs when you got your car tested at THOR Paul? Which paul m8 Me Paul or him Paul ? Thor - stock turbos October - Before mine blew the EGT's were mega high - sometimes over 1000 - the AFR's weren't too bad - but no real chance to check before 'BANG' Now - AFR actually slightly rich - whayyy too much fuel from pump / FSe and 550's with Hybrid turbos EGT's now max to 950 at full WOT load - before dropping back - normal cruising at 800 - so I'm please with that and hybrids Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 18, 2004 Share Posted May 18, 2004 Yep you, too many Pauls Thanks for the reply, was just curious to how under-fuelled the J-specs are at high boost, knowing the UKs run rather rich on the top-end. Thats the problem with high-boost on stockers, not just the risk of blowing them (as thankfully you did), but of the extreme EGTs. Of course both together is a really bad recipe. Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 18, 2004 Author Share Posted May 18, 2004 Originally posted by baldy u dont list a fuel pump! im running 1.45 bar boost,but have walboro pump & fse valve,&still on 440's How do you get the boost upto 1.45 bar of boost? Mine is actually only sitting at 1 bar boost. Does the restrictor need to come out? Paul. Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 18, 2004 Author Share Posted May 18, 2004 Originally posted by Paul E Paul - have a check in your petrol tank and see what pump you have there I am sure that the fuelling really contributed to the downfall of my turbos due to lean running at higher boosts and increased EGT's as a result I have the FSE and pumps here! How do I get into the petrol tank?? I'm too big to fit in the hole! seriously....how do I check? Paul. Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 18, 2004 Author Share Posted May 18, 2004 Originally posted by scooby_doo_do Sounds good Paul....... What time did you pick it up ? Was going to go tho the Bhurtpore inn for some beers, but the cab from the swan wanted £25 each way! So in the end we just stayed in the swan.... See the BMW outside I didnt pick it up until about 5:30. I saw the beamer yes. Didnt it break down on the way up here?? Paul. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 18, 2004 Share Posted May 18, 2004 If you want extreme boost, remove the restrictor, but be warned that sort of boost is bad news for the turbos and engine. Or get a EBC/bleed valve and up it to the safe max of 1.2bar. To get to fuel pump, remove spare in boot, and take off the six bolts holding the plate beneath it. Under this is the top of the tank, lift out the big circular lid and out comes the pump with it. Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 18, 2004 Author Share Posted May 18, 2004 Originally posted by Syed Shah If you want extreme boost, remove the restrictor, but be warned that sort of boost is bad news for the turbos and engine. Or get a EBC/bleed valve and up it to the safe max of 1.2bar. To get to fuel pump, remove spare in boot, and take off the six bolts holding the plate beneath it. Under this is the top of the tank, lift out the big circular lid and out comes the pump with it. Hiya, Sorry, I dont understand. I was under the impression that you could not fit a bleed valve to a J-spec? If I can fit a bleed valve then what was the point of taking the cat out and putting a restrictor ring in? Paul. Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted May 18, 2004 Share Posted May 18, 2004 Because a bleed valve like an EBC, can only raise boost from normal level, not lower it. Without the restrictor, your car would boost past 1.5bar, and a bleed valve/EBC could do nothing to lower it. Quote Link to comment Share on other sites More sharing options...
baldy Posted May 18, 2004 Share Posted May 18, 2004 hi paul im using a blitz dsbc to get the boost up still have the restrictor in so the boost peaks @ about 1.1 with the controller off cheers baldy Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted May 19, 2004 Share Posted May 19, 2004 Lol.... Yep the BMW broke down as i found a lose wire on the battery (Which was the main cable from the fuse box) and this in turn made everything on the car stop when it came lose.... Quite scary on the m25 in the middle lane ! But we drifted it to the side and eventually found the problem and its been fine ever since..Being that it hasn't moved for a year it didn't do all that bad. I had a look round your car yesterday though,,,, I love the wheels... I'm using a manual boost controller to up the boost on my car since i was only hitting 0.7 bar with all the stuff its had done. Now its on 1.2/1.3.... Craig. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted May 19, 2004 Share Posted May 19, 2004 Originally posted by Paul R How do I get into the petrol tank?? I'm too big to fit in the hole! seriously....how do I check? Paul. Check out Syeds instructions - just be prepared for some petrol leakage - safety precautions etc The black cover is a bitch to get of and you will prob have to tap round with hammer and 'blunt' chisel type implement Check out the two arrows marry up before and after! Cheers Paul Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 19, 2004 Author Share Posted May 19, 2004 Hi, Can someone send me a pic of where to plumb a bleed valve into? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
