jack cottam Posted November 25, 2006 Share Posted November 25, 2006 hI I have a 1993 Aerotop non turbo and the odometer ( in KM) has stopped clocking up. The trip meter will reset but will not click up. Any ideas Link to comment Share on other sites More sharing options...
SteveR Posted November 26, 2006 Share Posted November 26, 2006 Check the connection at the back by opening the dash up. Have you got a top speed delimiter or speedo convertor fitted? Link to comment Share on other sites More sharing options...
Mas Posted November 26, 2006 Share Posted November 26, 2006 this happened alot before to the guys here, and they normally get it sorted with disconnecting the battery for a few minutes and then connecting again. worth giving a try before opening the dash up Link to comment Share on other sites More sharing options...
jack cottam Posted November 27, 2006 Author Share Posted November 27, 2006 Thanks guys I will try these and advise. DOn't know whether a delimiter has been fitted by previous owner but odometer clicks in Km,s. If I disconnect the battery am I likely to encounter any probs with the immobiliser/alarm? Cheers again Jack Link to comment Share on other sites More sharing options...
stevie_b Posted November 27, 2006 Share Posted November 27, 2006 Hi Jack, Welcome to the club. Where abouts in Hants are you? I'm in Basingstoke. As for your problem, you should be OK disconnecting the battery as long as the immobiliser is off (i.e. engine not immobilised) when you do it. If the battery thing doesn't work, then you can remove part of the dash to get behind the odo. Don't worry, it's not as bad as it sounds. There are pictures on here somewhere that tell you exactly what to do and where to pull. If the battery reset doesn't work, then I guess that you've got a cheapo delimiter unit. Not too bad to replace, and a decent one (e.g. from Thor) should sort the problem out. Before splashing out on a new converter unit, you can test the odo circuitry to make sure it's OK. The odo counts electrical pulses at its input, so if you're OK with electrical stuff you should be able to send a pulse to the input and see if it ticks up by a digit on the display. Link to comment Share on other sites More sharing options...
