wkdtime Posted November 23, 2006 Share Posted November 23, 2006 Ok for those who have been following this thread...http://www.mkivsupra.net/vbb/showthread.php?t=89890 The problem turned out to be the FCD (TRL), when disconnected the car idles fine, but when it is connected the car idles erratically. The connections are solid i have treble checked, i even used a different ground point. I have the FCD Blue and green wire connected to the relevant points on the ECU and the live and earth connected at the relevant points behind the stereo. I have two questions, Firstly, does the FCD earth and 12v have to be taken fromt he ECU loom or is it ok as above? Secondly, is the FCD faulty? When the FCD is connected the car boost fine to 1.2Bar so i know the FCD is partly doing its Job. Found an old thread with exactly my problem http://www.mkivsupra.net/vbb/showthread.php?t=19932&highlight=fcd Quote Link to comment Share on other sites More sharing options...
wkdtime Posted November 23, 2006 Author Share Posted November 23, 2006 Anyone? Quote Link to comment Share on other sites More sharing options...
absz Posted November 23, 2006 Share Posted November 23, 2006 Never played with fcd not sure how they are wired. but i know jezzybabes had a faulty fcd on his car and it caused a erratic idle Quote Link to comment Share on other sites More sharing options...
mr lover Posted November 23, 2006 Share Posted November 23, 2006 i had exactly the same problem, called thor for advice and when they checked the no. on the chip inside i was told it was from a faulty batch and they replaced it for me Quote Link to comment Share on other sites More sharing options...
