is this meant to be missing
Guest Geneb
  • 2 weeks later...
So what model n/a's had lsd as stock cus i thought all n/a's were using the open diff style which uses same mounts at the front but only one on the rear....? unless its been modified internally in that case you would require the other mount for stability.
pic is from tt,n/a's are smaller and dont have the vents at the rear
I believe the LSD in a NA was a option you had to order. Both the NA and the TT auto (with or without LSD) only had the one mounting point in the rear of the differential.
