Guest Geneb Posted November 22, 2006 Share Posted November 22, 2006 is this meant to be missing the mount on the RH of diff Link to comment Share on other sites More sharing options...
Homer Posted November 22, 2006 Share Posted November 22, 2006 Is that an NA non-lsd diff, if so then its normal. Link to comment Share on other sites More sharing options...
Guest mk47 Posted November 22, 2006 Share Posted November 22, 2006 ps homer hows it going Link to comment Share on other sites More sharing options...
gledo1970 Posted November 22, 2006 Share Posted November 22, 2006 all the n/a's ive worked on have only one left hand rear mounting mate..think thats standard Link to comment Share on other sites More sharing options...
Digsy Posted November 22, 2006 Share Posted November 22, 2006 Mine's an NA with an LSD and I only have one mount. It worried me too until I found out it was normal Link to comment Share on other sites More sharing options...
Guest Geneb Posted November 22, 2006 Share Posted November 22, 2006 Thank fook for that so it on ramp today thought gremlins had been nickin bits offa it:d Link to comment Share on other sites More sharing options...
adi2009 Posted November 22, 2006 Share Posted November 22, 2006 LSD NA's dont have the other mount either Link to comment Share on other sites More sharing options...
dini_the_owl Posted December 1, 2006 Share Posted December 1, 2006 So what model n/a's had lsd as stock cus i thought all n/a's were using the open diff style which uses same mounts at the front but only one on the rear....? unless its been modified internally in that case you would require the other mount for stability. pic is from tt,n/a's are smaller and dont have the vents at the rear Link to comment Share on other sites More sharing options...
Guest DaveH Posted December 2, 2006 Share Posted December 2, 2006 I believe the LSD in a NA was a option you had to order. Both the NA and the TT auto (with or without LSD) only had the one mounting point in the rear of the differential. Link to comment Share on other sites More sharing options...
SatSport Posted December 2, 2006 Share Posted December 2, 2006 Very informative thread here http://www.clubna-t.com/forums/showthread.php?t=379 where Dave builds a LSD into the existing NA diff. Link to comment Share on other sites More sharing options...
