gaz1 Posted November 18, 2006 Share Posted November 18, 2006 just bought this and would like to know where and how to fit it, with pics if poss;) Link to comment Share on other sites More sharing options...
mr lover Posted November 18, 2006 Share Posted November 18, 2006 fitted mine to the back of the heat sheild http://img120.imageshack.us/img120/7392/catchtanknx1.jpg Link to comment Share on other sites More sharing options...
MR.B Posted November 18, 2006 Share Posted November 18, 2006 Nice looking bay you got there fella! Link to comment Share on other sites More sharing options...
supradibbs Posted November 18, 2006 Share Posted November 18, 2006 u been buying new wheels gaz:) Link to comment Share on other sites More sharing options...
JamieP Posted November 18, 2006 Share Posted November 18, 2006 Get in the car with catch tank... drive to turbofit and say "greg will you fit this for me please":D Link to comment Share on other sites More sharing options...
gaz1 Posted November 18, 2006 Author Share Posted November 18, 2006 u been buying new wheels gaz:) for the n/a yeah Link to comment Share on other sites More sharing options...
gaz1 Posted November 18, 2006 Author Share Posted November 18, 2006 Get in the car with catch tank... drive to turbofit and say "greg will you fit this for me please":D lol they are both going there soon so might just do that;) but would not mind having ago myself if its an easy job:D Link to comment Share on other sites More sharing options...
gaz1 Posted November 18, 2006 Author Share Posted November 18, 2006 fitted mine to the back of the heat sheild [qimg]http://img120.imageshack.us/img120/7392/catchtanknx1.jpg[/qimg] looking good mate thanks for the pic, Link to comment Share on other sites More sharing options...
alan_blue Posted November 18, 2006 Share Posted November 18, 2006 was also thinking of getting one of these as when i tok off the inlet to the throttle body there was quite a bit of oil, how come its on the other side of the engine then? Link to comment Share on other sites More sharing options...
Suprash Posted November 18, 2006 Share Posted November 18, 2006 Firstly catch tanks need to be fitted correctly, ie lower then were their being feed from. It seems my turbo issues are breathing related and not turbo themselves. Phoenix reckon my breathing system is struggling causing too much pressure to be put on the turbos, as my catch tank is a little to high, and some of my hose kit pipes are suffering collaps due to them not being heat rated. If you have oil in your inlet piping them its one of two things, 1) your cam breathers are throwing out some oil, make sure the breathers that go across the cam case are all ok, as I have been told if it cant breath across the cam case properly this can cause problems. 2) Your turbos are leaking oil, this could either be the turbos themselves or because your breathing system is failing putting extra pressure on your tubo seals.........sorry that went on abit, just trying to see, even something simple like a hose kit and catch tank can cause endless problems....... Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 18, 2006 Share Posted November 18, 2006 fitted mine to the back of the heat sheild [qimg]http://img120.imageshack.us/img120/7392/catchtanknx1.jpg[/qimg] Woah:cool: pass the Solvol:) Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 19, 2006 Share Posted November 19, 2006 Turbofit fitted my HKS Catch tank this week, great price to Link to comment Share on other sites More sharing options...
JohnA Posted November 19, 2006 Share Posted November 19, 2006 It could do with larger diameter hoses. The longer the path compared to stock, the larger the diameter has to be so the pumping losses are not increased. Here it looks like it's smaller than stock AND longer path. Link to comment Share on other sites More sharing options...
mr lover Posted November 19, 2006 Share Posted November 19, 2006 i was told to use 15mm pipes and not the smaller 9mm Link to comment Share on other sites More sharing options...
Suprash Posted November 19, 2006 Share Posted November 19, 2006 i was told to use 15mm pipes and not the smaller 9mm It should be 15mm pipes I believe........ Link to comment Share on other sites More sharing options...
JohnA Posted November 19, 2006 Share Posted November 19, 2006 Aye, at full boost and high revs a 2JZ of 'some' age will need a lot of crankcase ventilation. This narrow path can't hack it. Get some fuel-grade hose from your local motor factors and replace them. Best is the one with the coil inside, it doesn't collapse. Link to comment Share on other sites More sharing options...
alan_blue Posted November 19, 2006 Share Posted November 19, 2006 so where is best to fit one on a standard engine then? Link to comment Share on other sites More sharing options...
JohnA Posted November 20, 2006 Share Posted November 20, 2006 Here is how I did mine. Fits neatly and securely under the std airbox and intercooler pipe Link to comment Share on other sites More sharing options...
alan_blue Posted November 20, 2006 Share Posted November 20, 2006 what about doing one on the other side? ie near the throttle valve? Link to comment Share on other sites More sharing options...
JohnA Posted November 20, 2006 Share Posted November 20, 2006 that side can be pressurised, that's why it's got a one-way valve. If you are feeling adventurous, be careful not to pressurise the camcover (and consequently the crankcase). That wouldn't make you popular with the crank seal. Link to comment Share on other sites More sharing options...
