SilverSoop Posted November 16, 2006 Share Posted November 16, 2006 Hi guys wonder if you can identify the problem, it only started happening a couple of days ago when some woman who braked sharpely for no reason, my warning light on the dash appeared, you know the warning light for when the handbrake is applied, like this one as shown on the title at the top it shows up. Now when i brake normally it doesnt do it, when i brake quite firmly though it shows up and stays on for around 10-ish seconds. For a minute i thought it was the brake fluid, it was lower than what i thought so i topped it up, tried it again, it appeared once more. My mate reckons its my pads and i think the same. Any ideas?? Link to comment Share on other sites More sharing options...
Ric Posted November 16, 2006 Share Posted November 16, 2006 break fluid level. as mentioned in other threads even tho you just filled it up. under heavy braking it will flood to the front of the res and the sensor is quite sensative, put some more in Link to comment Share on other sites More sharing options...
squiffy Posted November 16, 2006 Share Posted November 16, 2006 pads may be low, causing fluid to be low. if you top it up you may have to take it back out when the pads run out Link to comment Share on other sites More sharing options...
LeeT Posted November 16, 2006 Share Posted November 16, 2006 break fluid level. as mentioned in other threads even tho you just filled it up. under heavy braking it will flood to the front of the res and the sensor is quite sensative, put some more in Surely you mean BRAKE fluid? But you are right. Also check pad wear Link to comment Share on other sites More sharing options...
Mike Posted November 16, 2006 Share Posted November 16, 2006 Yep, top up the fluid and it will stop... check this Link to comment Share on other sites More sharing options...
SilverSoop Posted November 17, 2006 Author Share Posted November 17, 2006 Well thanks guys, i filled it up on sunday and last night tried it out, the warning light appeared again. Pads?? Link to comment Share on other sites More sharing options...
Ric Posted November 17, 2006 Share Posted November 17, 2006 yes leet im dense Link to comment Share on other sites More sharing options...
Terminator Posted November 18, 2006 Share Posted November 18, 2006 I cant see how it could be pads, as there are no electrical pad wear sensor s on the MKIV. Link to comment Share on other sites More sharing options...
Jake Posted November 18, 2006 Share Posted November 18, 2006 I cant see how it could be pads, as there are no electrical pad wear sensor s on the MKIV. Pads wear and get thinner = pistons protrude from the calliper more = fluid level drops Link to comment Share on other sites More sharing options...
SilverSoop Posted November 18, 2006 Author Share Posted November 18, 2006 Yeah it could be that, as thats the only thing i can think of. When i was coming back from work tonight, did a bit of steady braking-everything was ok but when i had to brake hard for traffic lights and the roundabout, it came on and stayed on for a short while. If it was fluid it would come on regardless, but pads i think could well be the culprit. Link to comment Share on other sites More sharing options...
Homer Posted November 18, 2006 Share Posted November 18, 2006 That really does sound like fluid level. Is it topped up to the top of the 'Max' level? The system is incredibly sensitive. As others said check for pad wear, if they're very low then that could well be the cause. Link to comment Share on other sites More sharing options...
