SupraStar 3000 Posted May 11, 2004 Share Posted May 11, 2004 Hi, Anyone have experience (positive or negative) regarding Apex and/or HKS air filters. Apex - Power Intake HKS - Super Power Flow Not sure which to buy. The Apex seems to get better reviews and is cheaper, but the HKS looks cool and is more popular. Application on a: Supra Mk4 - (NA) BLITZ - NUR SPEC S EXHAUST (maybe relevant to choice) 1993 (Import) Gearbox Automatic Engine type 2JZ-GE (Model JZA80) 6 cylinder - 3,0 litre 24 valve Appreciate any help. Thanks, Ed http://www.david.c.c.btinternet.co.uk/Resources/suprastar.jpeg http://www.suprastar.org/ Link to comment Share on other sites More sharing options...
SkyJawa Posted May 11, 2004 Share Posted May 11, 2004 HKS filtration is crap compared to the Apexi and you will need to replace the filter part more often. So Apexi Link to comment Share on other sites More sharing options...
Zed Posted May 11, 2004 Share Posted May 11, 2004 The HKS filter was slaughtered by the Apexi in a test which you might be able to get a link to on mkiv.com. The Apexi is also a dry type filter so less chance of filter oil clogging up the intake as compared to say a K&N. Hope this helps!!!!!!!! Link to comment Share on other sites More sharing options...
Ian R Posted May 11, 2004 Share Posted May 11, 2004 No contest Apexi in every way looks filtration and performance Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted May 11, 2004 Author Share Posted May 11, 2004 Thanks everyone Cheers Zed, I found the link: http://mkiv.com/techarticles/filters_test/2/index.html Looks like the 'Apexi' is the clear winner. I have to admit, I am pleasantly surprised that the unit adds 14bhp to the engine. Link to comment Share on other sites More sharing options...
SKI Posted May 11, 2004 Share Posted May 11, 2004 I'm sceptical regarding those performance gains, unless you fit a really good airbox, you ever felt the heat from the engine that gets blow onto those intakes (it defeats the object), I'm suprised more people don't experience performance loss. Would be interesting to hear if any realistic tests have been done in the UK, not just marketing hype! I took mine off (Apexi) and fitted a TRD filter into the standard box, the Supra breathes fine up to 500 Bhp (so say the experts), you would be better of spending the money elsewhere. Link to comment Share on other sites More sharing options...
Terminator Posted May 11, 2004 Share Posted May 11, 2004 I went back to a stock box and Tom's panel filter after suffering heat enduced lag on the track unless I took the lamp out. No problems with heat in the induction system with the stock box. Uninsulated under bonnet air filters are a total waste of time and money IMHO unless bling is your thing. Link to comment Share on other sites More sharing options...
lust2luv Posted May 12, 2004 Share Posted May 12, 2004 Does anyone make any sort of airbox for the HKS? Link to comment Share on other sites More sharing options...
SkyJawa Posted May 12, 2004 Share Posted May 12, 2004 Yup - TDI do a carbon fibre one and Paul E does something too. Link to comment Share on other sites More sharing options...
Supragal Posted May 12, 2004 Share Posted May 12, 2004 I've got Apexi, more than happy with the noise too Link to comment Share on other sites More sharing options...
SkyJawa Posted May 12, 2004 Share Posted May 12, 2004 Originally posted by Supragal I've got Apexi, more than happy with the noise too Same here - though not on a Supe Getting used to it now though, better add some other noise to the car to make up for it Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted May 12, 2004 Share Posted May 12, 2004 I used to have the hks on mine but swapped to the apexi. Think unless your after bigger bhp stick with the stock airbox as the only real + is looks. I dont think you get any gain in bhp and also poorer filtration whichever filter you use. Doe's anyone know what sort of bhp you can get to useing the stock airbox ? Also can you get differant filters for the stk airbox or just o/e ? Regards Dunk Link to comment Share on other sites More sharing options...
Sharpie Posted May 12, 2004 Share Posted May 12, 2004 Originally posted by Andrew Dunk Shaw Also can you get differant filters for the stk airbox or just o/e ? Regards Dunk HKS/APEXi/KnN/TRD and a few more I bet. HTH Link to comment Share on other sites More sharing options...
SimonB Posted May 13, 2004 Share Posted May 13, 2004 Originally posted by Peter Sharp HKS/APEXi/KnN/TRD and a few more I bet. HTH Blitz LM too, that's what I've got. Link to comment Share on other sites More sharing options...
SkyJawa Posted May 13, 2004 Share Posted May 13, 2004 I got a K&N panel replacement for the stock TT airbox if anyone is interested. Only done about 500 miles Link to comment Share on other sites More sharing options...
V Posted May 13, 2004 Share Posted May 13, 2004 Originally posted by HISUPE I got a K&N panel replacement for the stock TT airbox if anyone is interested. Only done about 500 miles YES PLEASE Regards Stephen V Link to comment Share on other sites More sharing options...
