rovervi Posted November 16, 2006 Share Posted November 16, 2006 Has anyone sprayed the little black thing on the front at the bottom of the bumper on a Jspec, wanna do it but not sure if i will get the colour match and because of the material not sure if the paint will just fall off. Cheers Pete Quote Link to comment Share on other sites More sharing options...
IDO Posted November 16, 2006 Share Posted November 16, 2006 I was thinking of doing mine a wile back.. I did see someone with it done and it looked good.. as long as you use a good primer I am sure the paint should be ok (as long as you dont keep catching/scratching or twisting it).. As you said, not sure on how close the finish and colour will match due to the difference in the materials.. But as i said the one i saw did look good, so it can be done... Good luck Quote Link to comment Share on other sites More sharing options...
Max Headroom Posted November 16, 2006 Share Posted November 16, 2006 With the bottom lip being flexible, I am pretty sure you would need to consider a rubberised paint! Quote Link to comment Share on other sites More sharing options...
colsoop Posted November 16, 2006 Share Posted November 16, 2006 Garetheves did his and it looked good, send him a pm im sure he would advise you further. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 16, 2006 Share Posted November 16, 2006 You will first need a plastic primer, and also need to add some flexi additive to the base and lacquer. Quote Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 16, 2006 Share Posted November 16, 2006 mine is painted and looks fine. Was like this before I got the car tho. Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted November 16, 2006 Share Posted November 16, 2006 not an expret, but this is what i think will need to be done, as its a tough rubber, get a nice dull smooth snad on it, primer mixed with flex, then the silver mixed with flex and clear coat mixed with flex, as the paint will apply nicely on and will be able to bend a little without breaking. Quote Link to comment Share on other sites More sharing options...
rovervi Posted November 16, 2006 Author Share Posted November 16, 2006 thanks guys, how would you apply flex to the spray paint? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 16, 2006 Share Posted November 16, 2006 If you are intending to use spry cans? i don't know of any that have flxi additive in them, i was referring to paint that you mix and spray yourself. Quote Link to comment Share on other sites More sharing options...
rovervi Posted November 16, 2006 Author Share Posted November 16, 2006 If you are intending to use spry cans? i don't know of any that have flxi additive in them, i was referring to paint that you mix and spray yourself. hhmmm havent really got any spraying equipment so this is going to be a dead end for me unless i pay an arm and leg and get a body shop to do it Quote Link to comment Share on other sites More sharing options...
merckx Posted November 16, 2006 Share Posted November 16, 2006 Why would you need a flex additive? The plastic is quite rigid and it's only going to move if you catch it on something you shouldn't . It wouldn't do any harm to use some though. I've got mine done. Quote Link to comment Share on other sites More sharing options...
