Steve Sherwood Posted November 15, 2006 Share Posted November 15, 2006 As new HKS VVTi 264 cam kit and controller on ebay item number: 140053226774. Link to comment Share on other sites More sharing options...
Jake Posted November 15, 2006 Share Posted November 15, 2006 Hi Steve What makes you say it's a 272 cam? I didn't think they were that wild (I don't know for sure, just asking) was going to be fitted to my supra but decided to change the ecu for stand alone so i no longer need Huh? Am I missing the point here? Does that make sense to anyone? Link to comment Share on other sites More sharing options...
JustGav Posted November 15, 2006 Share Posted November 15, 2006 One of the pictures actually says 264 VVTi.... but yeah, why sell it because you are going SA? No sense... Link to comment Share on other sites More sharing options...
Kopite Posted November 15, 2006 Share Posted November 15, 2006 Depends which standalone. I'm using the AEM which offers full VVTI control so don't need the Valcon either Link to comment Share on other sites More sharing options...
Jake Posted November 15, 2006 Share Posted November 15, 2006 I'm using the AEM which offers full VVTI control so don't need the Valcon either So what intake cam are you using then? Who's mapping the VVTi advance/retard for you? Link to comment Share on other sites More sharing options...
Kopite Posted November 15, 2006 Share Posted November 15, 2006 264 JUN copy (most likely), Dimitri is mapping it Arnout is building it Link to comment Share on other sites More sharing options...
Wez Posted November 15, 2006 Share Posted November 15, 2006 Since when has the AEM been able to control the VVTI system? Link to comment Share on other sites More sharing options...
Kopite Posted November 15, 2006 Share Posted November 15, 2006 Universal/RACE AEM, not the Supra specific AEM http://aempower.com/ViewCategory.aspx?CategoryID=63 Link to comment Share on other sites More sharing options...
Wez Posted November 15, 2006 Share Posted November 15, 2006 Curious, wonder why they cant get it working on the Supra EMS then. Link to comment Share on other sites More sharing options...
Kopite Posted November 15, 2006 Share Posted November 15, 2006 Arnout says it is possible but a lot easier with the other AEM unit which also includes peak and hold on the injectors etc Link to comment Share on other sites More sharing options...
Wez Posted November 15, 2006 Share Posted November 15, 2006 Hmmmm, ok. Do you know what method in the AEM is being used to control the VVTI system? Link to comment Share on other sites More sharing options...
Steve Sherwood Posted November 16, 2006 Author Share Posted November 16, 2006 Sorry it is a 264 cam. I run 272 non VVTi cams in my VVTi head the car makes 850 rear hub hp on a 72mm turbo do I need VVTi? Also I did the conversoin some time ago no one at that time could map the AEM to run the VVTi. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 16, 2006 Share Posted November 16, 2006 Sorry it is a 264 cam. I run 272 non VVTi cams in my VVTi head the car makes 850 rear hub hp on a 72mm turbo do I need VVTi? Also I did the conversoin some time ago no one at that time could map the AEM to run the VVTi. Sounds an interesting engine Steve. Any issues with none VVTi cams? I take it they are in a VVTi head casting, or did you fit an earlier head? Link to comment Share on other sites More sharing options...
Miguel Posted November 16, 2006 Share Posted November 16, 2006 How did you do that Steve ? The intake cam on the VVTi is totaly different as is the head casting on that side. Be interesting to know how you use a normal 272 cam in that side Link to comment Share on other sites More sharing options...
Steve Sherwood Posted November 16, 2006 Author Share Posted November 16, 2006 How did you do that Steve ? The intake cam on the VVTi is totaly different as is the head casting on that side. Be interesting to know how you use a normal 272 cam in that side We had the front cam journal machined to fit the housing extra oil feed hole and groove cut. Through the motor build project we have tried to be innovative rather than fitting bolt on kits. Sometimes things just dont work but usually its ok. Link to comment Share on other sites More sharing options...
Miguel Posted November 16, 2006 Share Posted November 16, 2006 Excelent stuff Link to comment Share on other sites More sharing options...
