supra steveo Posted November 15, 2006 Share Posted November 15, 2006 bollox!!!!!!!!!!!!!, just blown a headlamp thing is I've tried to replace it and oh shit the bulb doesn't fit so i am off the road tonight and i am off to Toyota tomorrow to get a new one. how much do these cost ? i have got a feeling they are going to be expensive:( Link to comment Share on other sites More sharing options...
Rayman Posted November 15, 2006 Share Posted November 15, 2006 Can you not just go to halfords and get a replacement? Its the bulb thats blown is it? Link to comment Share on other sites More sharing options...
markymark Posted November 15, 2006 Share Posted November 15, 2006 I'm sure you cant get these bulbs from Halfords as the bulb is attached to the holder. Link to comment Share on other sites More sharing options...
Guest Tonysupra Posted November 15, 2006 Share Posted November 15, 2006 I had to get a standard Halfords bulb 6005 or so but see previous posts on this and you need to file off some of the plastic wings which keep the bulb in the holder and also there is a rib that sticks up inside the connection bit that you chisel out. Very easy to do. I have J spec with J spec lights still. Link to comment Share on other sites More sharing options...
supra steveo Posted November 15, 2006 Author Share Posted November 15, 2006 Germany doesnt have halfords Link to comment Share on other sites More sharing options...
blitz supra Posted November 15, 2006 Share Posted November 15, 2006 I had to get a standard Halfords bulb 6005 or so but see previous posts on this and you need to file off some of the plastic wings which keep the bulb in the holder and also there is a rib that sticks up inside the connection bit that you chisel out. Very easy to do. I have J spec with J spec lights still. Bulbs are the normal ones as used in most Jap cars Mitsubishi Lexus etc etc etc Part No 9004 Part No 9005 One is high beam the other low beam Can't remember which is which though Any motor Shop / garage / Halfords etc etc sell them Link to comment Share on other sites More sharing options...
ivan Posted November 15, 2006 Share Posted November 15, 2006 UK Spec: Low = 9006 (HB4) High = 9005 (HB3) JSpec: Low = 9006J High = 9005J However the J bulbs are not available in the UK. The problem is that the 9006J and 9006 have different diameter bodies (20mm and 22mm respectively). To get around this what you do is to fit a 9005 (HB3) bulb in the high AND low beams (you will need to slightly modify the connector to make them fit though.) (Copyright the ImportPimp 21-01-06. ) 9005's should be available over there somewhere Steve. They don't all drive beemers and Audi's. MarkyMark, the bulb may be attached to the holder but that's what you replace - the whole thing. Link to comment Share on other sites More sharing options...
blitz supra Posted November 15, 2006 Share Posted November 15, 2006 UK Spec: Low = 9006 (HB4) High = 9005 (HB3) JSpec: Low = 9006J High = 9005J However the J bulbs are not available in the UK. The problem is that the 9006J and 9006 have different diameter bodies (20mm and 22mm respectively). To get around this what you do is to fit a 9005 (HB3) bulb in the high AND low beams (you will need to slightly modify the connector to make them fit though.) (Copyright the ImportPimp 21-01-06. ) 9005's should be available over there somewhere Steve. They don't all drive beemers and Audi's. MarkyMark, the bulb may be attached to the holder but that's what you replace - the whole thing. Which bit do you modify?? I just put them straight in my j spec But thinking about it, I did just the low beam bulb Also had to remove the bulb plug and put on insulated tiny spades as for some reason I had bad corrosion on just that one bulb connection yet its sealed inside the lamp behind a cover .. very weird Link to comment Share on other sites More sharing options...
ivan Posted November 15, 2006 Share Posted November 15, 2006 Which bit do you modify?? The 9005 bulb socket has two locating lugs while the wiring loom plug has just 1. Just trim the ones out of the bulb socket with a craft knife and Robert's your Dad's brother. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=21649&d=1127859752 Link to comment Share on other sites More sharing options...
supra steveo Posted November 17, 2006 Author Share Posted November 17, 2006 got one, the euro spec one with different sized lugs lucky they are going on a set of euro spec lights so i will still need to get a J spec one for when i am in the UK 20 euros it cost tho i nearly choked, a bit expensive i thought Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Share Posted November 17, 2006 so looking at the pictures here... http://www.mkivsupra.net/vbb/attachm...9&d=1127859752 what is it that you need to trim off? Link to comment Share on other sites More sharing options...
