Chris and Alana Posted November 14, 2006 Share Posted November 14, 2006 Hi guys, this toppic is probably talked about alot but I done a search and couldnt find the info I was needing. I fitted a boost gauge in place of my clock and wired it into the cig wiring loom, which works fine but I 'T' in the vac tube onto the vac tube off the dump valve, is this bad/wrong? because i found a web page that says it should be 'T'd into a vac pipe near the throttle body but does it really make much if any difference? Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 14, 2006 Author Share Posted November 14, 2006 :help: :help: :help: :help: :help: Link to comment Share on other sites More sharing options...
alan_blue Posted November 14, 2006 Share Posted November 14, 2006 im also wondering where peeps plumb there boost guages in too Link to comment Share on other sites More sharing options...
MKIVDreamer Posted November 14, 2006 Share Posted November 14, 2006 I think the favourite place to T off is the stock turbo pressure sensor hosing off the throttle body. This might help Or someone else may be able to provide a better location...? Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 14, 2006 Author Share Posted November 14, 2006 Please help us any of you people in the know [sAD][/sAD] Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 14, 2006 Author Share Posted November 14, 2006 I think the favourite place to T off is the stock turbo pressure sensor hosing off the throttle body. This might help Or someone else may be able to provide a better location...? Thank's for the link, very usefull but I have already plumbed mine into the vac tube off my dump valve and was needing to know if this is ok or would I have to extend my vac tube and T in into the vac tube off the throttle body? whats the difference? Link to comment Share on other sites More sharing options...
merckx Posted November 14, 2006 Share Posted November 14, 2006 http://img83.exs.cx/img83/8710/boost.jpg The hose marked in red goes to my boost gauge. The sensor with the green label on top(turbo pressure sensor), I pulled the hose from this and connected a couple of inches of new hose onto the sensor. Connect all 3 ends with a T piece: 1. Existing hose which you pulled off the sensor. 2. New hose (2 inches) which you've just fitted to the sensor. 3. New hose which runs to your boost gauge. Can you see the T piece (it's white) and the three hoses? Link to comment Share on other sites More sharing options...
mr lover Posted November 14, 2006 Share Posted November 14, 2006 this where mine is plumbed in http://img136.imageshack.us/img136/7162/boostgaugepickuppointvb6.jpg Link to comment Share on other sites More sharing options...
Ark Posted November 14, 2006 Share Posted November 14, 2006 Doesn't really make any difference - a vac-reference pipe is going to be the same just about anywhere. In theory you will get a quicker and more accurate response, the closer you are to the manifold, due to pressure waves. In practice it makes no difference for the pressures and piping diameters we are talking about, not for a gauge anyway. Link to comment Share on other sites More sharing options...
Pete Posted November 14, 2006 Share Posted November 14, 2006 There was a place that wasn't good to go from just in case the hose popped off. Forget where now. Mine is like MerckX Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 14, 2006 Author Share Posted November 14, 2006 Thanks guys and thanks for the pics, they are the most usefull and detailed pics Iv seen on this issue, thanks So am I rong to leave it plumbed into my dump valve vacume hose? Will I get false readings? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 14, 2006 Share Posted November 14, 2006 Its the blue pipe to the right of the one T'd off above Pete!! Leave well alone, even though mkiv.com tells you this is the one to use Just for the record, mine is t'd off the BOV actuator pipe with no problems whatsoever and is very accurate So am I rong to leave it plumbed into my dump valve vacume hose? Will I get false readings? nope totally fine Link to comment Share on other sites More sharing options...
Chris and Alana Posted November 14, 2006 Author Share Posted November 14, 2006 thanks very much mikey, my mind is finally at ease. It seems most people take it from close to the throttle body but i figured the pressure should be the same allong all the vac lines. I have changed my standard valve and replaced it with a HKS SSQV and T'd in off the vacume tube. So everything should be fine and accurate? Thanks for all the input guys, very helpfull Link to comment Share on other sites More sharing options...
Pete Posted November 14, 2006 Share Posted November 14, 2006 Its the blue pipe to the right of the one T'd off above Pete!! Leave well alone, even though mkiv.com tells you this is the one to use That sounds about right. Don't do that then! Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 17, 2006 Share Posted November 17, 2006 so why take it from the TPS when you can just easily take it from the BOV vac hose? Link to comment Share on other sites More sharing options...
JohnA Posted November 17, 2006 Share Posted November 17, 2006 this where mine is plumbed in [qimg]http://img136.imageshack.us/img136/7162/boostgaugepickuppointvb6.jpg[/qimg] funnily enough, so is mine:d We also share the same paint blister on the camcover. Same cabletie too! Small world. Link to comment Share on other sites More sharing options...
