Traders Sig's - Too Big ?
Sharpie
Guest Terry S
Originally posted by SimonB
Yeah, you just need to browse Supraforums to see how annoying sig pictures can be!
Totally agree
Originally posted by Terry S
Totally agree
Seconded!:thumbs:
But I'm still keeping mine - it gives me something to read!:p
In fact I think I will make it longer!
And put up all my hobbies / cars / girlfriends / favourite positions etc....
List all the mods
List all the mods that I want to do
Those I cant afford / those that Fred down the road is doing for me
With a huge pic of the car from front / rear / side etc
C'mon guys - I mean I know @sh (bless him!) went a bit overboard before but this path does then endanger ANY individuality!
:cool:
Well, seeing as the more informed among us have let it be known that the text in the sig does not slow down the loading times etc, all I can say is
Who Gives a Shit?
I mean FFS guys, is it really that much of an issue?
Originally posted by stealthhosts
Text is a matter of bytes which on a 56k modem you should be download 56000bytes a second (give or take)
No it isn't. If you run a hosting company you should know better than that.
pffft - bits then
and an absolute maximum of 57,600bps (yes I know its higher than rated)
Was simply trying to put it in a way that all would understand, regardless of knowledge on the subject.
and for those not content with that 1kilobyte = 1024bytes, 8bits = 1byte and depending on compression, latency and frequency you can obtain speeds in excess of your "bandwidth" or modem limitation, you can also shotgun your modems to give a theoretical speed of 115,200bps. If you are on a v.92 modem then the above speeds are all accurate, if not then you may only get a speed of ~45-55000bps due to the different standard used by the modem itself and its compression ratio's
Forgive me if my original post confused anyone
Originally posted by Chase
...So, who is the largest/biggest supplier of Supra parts in the UK...and are they the same thing...
:innocent:
Have we got a 'can of worms' smiley :D
We are - I just add all those that Envy is selling to those Paul W has got - add a smattering of Performa and some Vortex spin!
Then off to Miami for a lie down!
That must be about 20,000 lines
All in stock in our warehouse!
:p
Forgot to add that my previous statements were based on standard home-ISP common practice, anyone (like me) billed at the 95%ile may have a burstable pipeline that could boost up to 35gbps on a standard OC256 and that speed/billing on a 95th percentile connection would be based on mean usage and not on minimum/maximum unsustainable rates.
Wouldn't want anybody to feel they had been incorrectly informed now, would I?
either way it's about 5 thousand characters of text a second on a 56k dialup but I agree that big fat sigs with massive writing filling half the screen can be a bit of an eye sore :)
As can poor punctuation ;)
the problem with big sigs is the actual size of them, they can be larger than the post somebody is making in some cases.
People tend to get round that by using a much smaller font than normal which is my preference. The traders using BIG fonts seems to be tit-for-tat, if the traders and performance tuners can just check their own sigs and if theres a way to avoid the BIG text please do.
JB
Guest Terry S
No worries, I will do mine now. If the others are grown up enough to follow it will stay that way:thumbs:
Originally posted by Performa
:) i dont think i need to change anything on mine. although it has grow fron 1 line to 2 :innocent:
There's just no stopping people once they get the bug eh? :)
