Main Belt
Phil Wall
Hi  Guys,
Does anyone know how critical the A- B settings are on a new belt. I have just fitted and new one and the pointer falls about 0.5 mm. outside the B range. Should I take it off and put the old one on,or is this ok?
The manual says wrong belt if outside B marks.
Is this a Toyota sourced belt?
If so, funny it should be outside the marks. I guess you are sure it *is* fitted properly? Hmm, if it *is* a Toyota belt then I'd certainly take it back to them. To my mind those limits are set for good reason and I would want the tensioner about mid-way (as per normal).
Yours,
J
