Guest 2 slow 2 low ! Posted November 13, 2006 Share Posted November 13, 2006 Car feels sort of detatched from the road occasionally !!! The rear of the car seem to move on the road sometimes, worse at motorway speed It's kind of a similar effect to a snaking when towing a large trailer, gets a bit of momemtum and doesnt settle back into line straight away. I havent had tracking done for a good while but wouldnt have thought it would have such an effect Any1 had similar problem? This is on a BMW 325 Coupe e36 Quote Link to comment Share on other sites More sharing options...
Ian R Posted November 13, 2006 Share Posted November 13, 2006 Nope just inapporative indicators is the common fault Quote Link to comment Share on other sites More sharing options...
Ian W Posted November 13, 2006 Share Posted November 13, 2006 have a very similar problem on my Supra unfortunately and don't have the foggiest what it is. will someone else with this problem pleeeeaaase fix it!! Quote Link to comment Share on other sites More sharing options...
BURT Posted November 13, 2006 Share Posted November 13, 2006 what mileage has it done matey..... could be the rear bushes, giving too much play. you may be better off asking here.http://www.bm3w.co.uk/index.php. you may bet more of a response bud;) Quote Link to comment Share on other sites More sharing options...
absz Posted November 13, 2006 Share Posted November 13, 2006 sounds like rear trailing arm bushes, quite commom on bmw's:) Quote Link to comment Share on other sites More sharing options...
Guest 2 slow 2 low ! Posted November 13, 2006 Share Posted November 13, 2006 its had new trailing arm bushes, next step, rear top mounts an shocks see what that does Quote Link to comment Share on other sites More sharing options...
Homer Posted November 13, 2006 Share Posted November 13, 2006 Shocks shouldn't cause the rear end to snake, really sounds like a major rear bush problem. Had the same problem on my 328i e36 and ended up with the rear trailing arm bushes being replaced. Quote Link to comment Share on other sites More sharing options...
Marty Posted November 13, 2006 Share Posted November 13, 2006 It basically tries to lob the back end about if you go over a grid or something, to the point where its actually kinda dangerous. The Bushes have just been changed. shocks on the rear are leaking slightly but that wont be causing the problem. Any other ideas? Quote Link to comment Share on other sites More sharing options...
Homer Posted November 13, 2006 Share Posted November 13, 2006 Its not had a smack on the rear end at all? Especially hit a curb hard? They don't take kerb shunts very well at all and can easily bend an arm (same as the Supra). That'd certainly cause major instability Quote Link to comment Share on other sites More sharing options...
absz Posted November 13, 2006 Share Posted November 13, 2006 i'll get the bushes checked again if it was me, as the trailing arm bushes if not fully pressed into there housing while fitting can come loose. Quote Link to comment Share on other sites More sharing options...
Guest 2 slow 2 low ! Posted November 14, 2006 Share Posted November 14, 2006 had the bushes replaced by a bmw garage so i trust there work an for what i payed i hope they put them in right, alot of people say top rear mounts an tracking, i`ll do all of the above an see what happens thank you all for your suggestions Quote Link to comment Share on other sites More sharing options...
Lucifer Posted November 14, 2006 Share Posted November 14, 2006 Bushes - Always on thise. Either rear trailing arms of front lower rear oil filled bushings. Quote Link to comment Share on other sites More sharing options...
Guest 2 slow 2 low ! Posted November 17, 2006 Share Posted November 17, 2006 FIXED!!! i changed the shocks an top mounts yesterday an the car now drives like a dream, the shocks where bolloxed, could push them in an out with me toe nail!! an they where leaking, well happy! Quote Link to comment Share on other sites More sharing options...
