Torque wrenches....advice needed
Guru
Couldn't under the wheel nuts this weekend just gone so am looking at torque wrenches as I only have a Halfrauds drive socket wrench at the moment.
Now Halfrauds have a 40-200Nm one for £50 but I have found a Sealey 20-150lb one for only £20. I have never had one before so am looking for a reccomendation please :)
No, but it's a good idea to use one when putting them back on.
True, but he did say he couldn't under [undo?] them. In which case a torque wrench is about as much use to him as a large slice of edam. :p
Guru, if you want to get wheel nuts off easily, get one of the extending wheel brace things - extend up to about 2' long, and come with changeable heads for 4 different sizes of nuts. You can pick them up from places like Halfords for
Britool are the best. Lovely feel to them & the windy uppy bit pulls out of the base and twiddles round really lovely... a bit like a nipple bar !!
A bit like this one. Britool Classic £103
25 to 135 Nm
http://www.tooled-up.com/artwork/ProdImage/TB16463.jpg
Phwwwooorrrrrr !
Britool?? What about say Norbar?? http://www.norbar.com/products_category.php&category_multid=1
They are good enough for the entire armed forces (thats why I have a few in my tool box :) ). Britool are OK but I much prefer the norbar stuff. You are paying for accuracy btw. Also I'm not sure what you mean by not undoing nuts with torque wrenches as most I have ever used come in reversible formats and get calibration checked every 3 months without losing their calibration over years. The winding the spring off is a good pointer though.
OOOO torque wrenches I think I just got a stiffy :)
as with anything in life mate you pay for what you get and my experience of Sealy is its cheap and the quality is not to good, it all depends what you want to do with it, if its just wheel nuts and the odd job then its fine, even if the Sealy is not very accurate it should be repeatable, if you set it to 90nm then everything should be between 85-95nm but more importantly all the same, so even if its not accurate all your wheel nuts will be done up the same ie 92nm, i would get one mate even if its just for wheel nuts swinging on a breaker bar is not the correct way to tighten them
What, you want a torque wrench to undo your wheel bolts?!
Sorry didn't explain well enough. I am having trouble undoing them. Getting a 60cm breaker bar for that and will get a torque wrench to do them up again properly insetad of just guessing ( which probably caused the problem) :)
