Warning lights - RHS of top dash
Guest Geneb
If I'm not mistaken, the lights all share a common switched negative, which is pin 3 for a J-spec (top row of 4, 3rd from the left as you look at the connector plug). If none of them are working you might want to start looking there, or indeed at the fuses in the left or right hand side kick panels.
