Chiefgroover Posted November 12, 2006 Share Posted November 12, 2006 1. Whats the red button with jap writing at it for? 2. My car has a strong tendancy to creep forward quite fast? whats up? 3. When holding my foot on the brake and car is in drive it rumbles through the body, is this normal on a vvti, mates Uk spec doesnt do these things. As you can tell, I know as much about auto trans as I know about jet engines. Link to comment Share on other sites More sharing options...
Jake Posted November 12, 2006 Share Posted November 12, 2006 1, for taking it out of Park when the engine is off. 2, not sure what you mean 3, no, not normal 4, YOU bought an auto???!!! :shocked: Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 12, 2006 Author Share Posted November 12, 2006 2. car will go forward when in drive at tickover, mates Uk spec stays stationary. It almost an effort to keep the car from going forward at the lights. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 12, 2006 Author Share Posted November 12, 2006 Jake did you post me that disc? please? Link to comment Share on other sites More sharing options...
psymon Posted November 12, 2006 Share Posted November 12, 2006 All Auto's creep when in drive...... Makes hill starts great... Remedy cover the brake. :d Link to comment Share on other sites More sharing options...
Jake Posted November 12, 2006 Share Posted November 12, 2006 2. car will go forward when in drive at tickover, mates Uk spec stays stationary. It almost an effort to keep the car from going forward at the lights. Oh I see. Yeah, that's quite normal. Both my autos do it. When the engine is cold, from a standing start on flat ground I can (eventually) get into 3rd gear without touching the throttle at all. Jake did you post me that disc? please? Yes mate, last week. Thursday I think it was Link to comment Share on other sites More sharing options...
ivan Posted November 12, 2006 Share Posted November 12, 2006 1. You should definitely know better. Link to comment Share on other sites More sharing options...
JohnA Posted November 13, 2006 Share Posted November 13, 2006 First I thought this is a windup. But if you hadn't had an auto before (I didn't!) then I guess they're reasonable questions. Yes, it's normal for the car to want to creep forward in D. You should need to press the brake pedal if you want to be stationary in D. The power it takes to push the car slowly forward like this in D, is roughly the amount wasted in transmission losses in the torque converter (don't worry, it's only fluid slipping internally, it's not a clutch) Makes start-stop traffic a breeze, you just leave in 'D' and regulate with the brake pedal. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 13, 2006 Share Posted November 13, 2006 Makes start-stop traffic a breeze, you just leave in 'D' and regulate with the brake pedal. im with you on that Link to comment Share on other sites More sharing options...
Burna Posted November 13, 2006 Share Posted November 13, 2006 What do you think of the tiptronic Chief? Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 13, 2006 Author Share Posted November 13, 2006 ok so my mates 94 jap car is the odd one as it doesnt creep forward. I am really getting to like the auto tip, but I dont fancy it for track work. Link to comment Share on other sites More sharing options...
Ian R Posted November 13, 2006 Share Posted November 13, 2006 Sorry I feel I must Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 13, 2006 Author Share Posted November 13, 2006 I am abusing the question system as I cant be arsed to look it up. Link to comment Share on other sites More sharing options...
Ian R Posted November 13, 2006 Share Posted November 13, 2006 I am abusing the question system as I cant be arsed to look it up. Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2006 Share Posted November 13, 2006 I am really getting to like the auto tip *AHEM* Link to comment Share on other sites More sharing options...
npotts Posted November 13, 2006 Share Posted November 13, 2006 Hi mate I had a tiptronic vvti, and it also did questions 2 and 3 - I wouldnt worry about it... Link to comment Share on other sites More sharing options...
martin_a Posted November 13, 2006 Share Posted November 13, 2006 tiptronic? anyway as said quite normal. Your mates car might be the one that is cream crackered with a worn torque convertor. you can replicate this in amnual, if you pull the clutch up and don't touch the accelerator the car will creep forward. Most electronic fuel and ECU systems will adjust the idle for the load on the engine, this means that at very low revs the car won't stall (don't stick it in second and pull clutch up it will stop but very slowly in 1st...) as the clutch is engaged (same as putting car into 'D') and revs are being applied the car will move forward. m. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 13, 2006 Author Share Posted November 13, 2006 *AHEM* eeeerrrrr eemmmm well I kinda made a typo there emmm errrrr you'd almost sorta know yourself Been too long since i drove a manual Supra, but I'll be back in one soon enough! p.s. Thanks for the disc, arrived today! Link to comment Share on other sites More sharing options...
