Kev.O Posted November 12, 2006 Share Posted November 12, 2006 I'm having trouble starting my car. Today I've checked all the spark plugs and they are all sparking. I've also used the correct connectors and holders so I know everything is working correctly. The spark plugs are covered in fuel so I'm assuming there's fuel getting to them. I've checked for split pipes but haven't found anything. When I turn her over she isn't even trying to start it's like theres no spark, which is why I checked the plugs. I'm running out of idea's. Can anyone offer any help please? Kev Link to comment Share on other sites More sharing options...
absz Posted November 12, 2006 Share Posted November 12, 2006 more details please. ie has it been parked up for a while, is it standard or modded:) Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 Well I drove the car to japfest 2 about a month ago. The car ran fine. I parked the car up in the garage and went to start it the next day. It started but was misfiring. Once I'd stopping it, it wouldn't start back up. After cleaning the spark plugs twice(first time for carbon build up and second for excess of fuel) it started but wasn't running on all 6. After a minute or two it was running fine again. I started it up two weeks again and after a few turns it started, went for a little run where it was misfiring again. The car has been sat around for two weeks on charge. It's bpu Link to comment Share on other sites More sharing options...
NUTKIN Posted November 12, 2006 Share Posted November 12, 2006 Just a thought what about a sensor of some sort playin up Link to comment Share on other sites More sharing options...
RobSheffield Posted November 12, 2006 Share Posted November 12, 2006 It's bpu Did you fit new plugs when you went BPU? If so, check the coil pack connectors Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 I checked them earlier. I got the coil back out and connected the correct one in the right place and put a spark plug in each one and turned the engine over. Link to comment Share on other sites More sharing options...
alan_blue Posted November 12, 2006 Share Posted November 12, 2006 did you get a apark between each terminal on each coil pack? Link to comment Share on other sites More sharing options...
absz Posted November 12, 2006 Share Posted November 12, 2006 sounds like its over fuelling on cold start? . check all your vacuum pipes for any splits and might be worth checking the coolant temperture sensor. if you just want to get the engine started then i suggest take out all plugs burn off the excess fuel of them by a small flame over the tip (gas cooker) and refit plugs hold the gas pedal half way and crank over engine. i'm sure it will fire up:) then you can checks for leaks etc while engine is running. Link to comment Share on other sites More sharing options...
Bobbeh Posted November 12, 2006 Share Posted November 12, 2006 Yeah, I was gonna say it sounds like its flooded.. tried giving it a bump start? Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 12, 2006 Share Posted November 12, 2006 Have you checked for fault codes? Link to comment Share on other sites More sharing options...
alan_blue Posted November 12, 2006 Share Posted November 12, 2006 manual or automatic? for bump start issues? Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 12, 2006 Share Posted November 12, 2006 manual or automatic? for bump start issues? Going by his sig, 95 UK TT Manual Silver Link to comment Share on other sites More sharing options...
TLicense Posted November 12, 2006 Share Posted November 12, 2006 Step one has to be to, as Mr Harwood said, to check for fault codes. Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 I've followed the guide for fault codes but was unable to get any response from the car. I appreciate all the help guys. As for a bump start, dam it's a heavy car (being UK spec and all ) it'll take loads of people to do that. Link to comment Share on other sites More sharing options...
Bobbeh Posted November 12, 2006 Share Posted November 12, 2006 Wouldnt expect you to do it on your own m8 Get some help! Then when it starts to tick over, give it a good run Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 Wouldnt expect you to do it on your own m8 Get some help! Then when it starts to tick over, give it a good run Do you think that'll work? Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 12, 2006 Share Posted November 12, 2006 The only downside to that, is be prepared to push it back home if it doesn't start! What happened when you checked for faults? - Did the MIL light just keep flashing? Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 No lights came on atall. It was like I wasn't doing it properly. I followed the guide that I found on here and I tried it several times! Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 12, 2006 Share Posted November 12, 2006 Does your MIL light work? (the orange engine light on the right side of the dash-top panel, next to the two oil lights). Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 I'm pretty sure it does. I'll double check Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 Ok just been out to the car. When I turn the ignition on, the only lights I get on the right are the handbrake light and trc light Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 12, 2006 Share Posted November 12, 2006 OK, first things first. You need to remove the dash top section, (5 screws), and re-solder the connections that go to the lamps on the right. You'll need to undo the two screws that hold the lamp cluster in place, then the two screws that hold the two pieces together. It'll be obvious when you take it apart. It's not a difficult job, and its a common fault. Once you've done that, you can check your fault codes and begin to find out why the car won't start... Link to comment Share on other sites More sharing options...
Kev.O Posted November 12, 2006 Author Share Posted November 12, 2006 Thank you Matt. Link to comment Share on other sites More sharing options...
Kev.O Posted November 13, 2006 Author Share Posted November 13, 2006 Just out of curiousity (and confusion after reading other threads) what is the technical name for the big red triangle bulb in the middle of the dash? Link to comment Share on other sites More sharing options...
Kev.O Posted November 13, 2006 Author Share Posted November 13, 2006 Ok I've soldered the connectors and I've done a fault code check. It was blink pause blinkblinkblinkblink pause I believe this is fault no.14 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13920&d=1112558346 what exactly does this mean? Link to comment Share on other sites More sharing options...
