Removing throttle body
SimonB
How easy is it to remove the throttle body? I've got a trac removal jobby to fit. Had a quick look this afternoon and it looks real awkward to get to the bolts that hold it on at the bottom. Can't even see the one on the right! Or is it just a case of taking the IC pipe and battery out to get a bit more room?
Very easy.
Remove the IC pipe and battery, and the 2 nuts and 2 bolts. There is also a coolant line attached to the bottom of the TB, use the 2 bolts to block them when you remove it. There is a gasket between the mani and B that needs to be reused as well.
Won't take you more than 10 mins. :)
