SimonB Posted May 9, 2004 Share Posted May 9, 2004 How easy is it to remove the throttle body? I've got a trac removal jobby to fit. Had a quick look this afternoon and it looks real awkward to get to the bolts that hold it on at the bottom. Can't even see the one on the right! Or is it just a case of taking the IC pipe and battery out to get a bit more room? Link to comment Share on other sites More sharing options...
Syed Shah Posted May 9, 2004 Share Posted May 9, 2004 Very easy. Remove the IC pipe and battery, and the 2 nuts and 2 bolts. There is also a coolant line attached to the bottom of the TB, use the 2 bolts to block them when you remove it. There is a gasket between the mani and B that needs to be reused as well. Won't take you more than 10 mins. Link to comment Share on other sites More sharing options...
SimonB Posted May 10, 2004 Author Share Posted May 10, 2004 Cheers Syed, guess it's not as awkward as it first looks. Just got to find the time now... Link to comment Share on other sites More sharing options...
