supRo Posted November 9, 2006 Share Posted November 9, 2006 I have aquired a stock TT air box. Sadly one of the plastic hinges on the lid is not there so won't be air tight around that area! Options to fix: 1, drill a small hole on the casing (there is enough plastic to not drill right into airbox) and use a cable tie 2, Wilkos do assorted semi circular metal clips - one of them may stretch over the two parts and hold it tight 3, wrap tape around the whole air box! 4, other - please suggest! Thank you, Ro Quote Link to comment Share on other sites More sharing options...
Jake Posted November 9, 2006 Share Posted November 9, 2006 I bet it's the left hand one broken? Must be one of the commonest fault on Supras - they're all like it! I'm not helping much, am I dad? [/DickEmery] Quote Link to comment Share on other sites More sharing options...
Homer Posted November 9, 2006 Share Posted November 9, 2006 I can sell you a mint condition full airbox for a non too small sum TBH, If its the clip on the main unit that have gone then drill a screw in there, it'll be air tight and won't look untidy. Quote Link to comment Share on other sites More sharing options...
DamanC Posted November 9, 2006 Share Posted November 9, 2006 i superglued mine back on, its almost airtight. I bet im not helping either. Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted November 9, 2006 Share Posted November 9, 2006 How do you change your filter if you've superglued the lid on? Quote Link to comment Share on other sites More sharing options...
redtwinturbo Posted November 9, 2006 Share Posted November 9, 2006 How do you change your filter if you've superglued the lid on? Lol I was thinking that as well. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 9, 2006 Share Posted November 9, 2006 I was going to say that I can supply new lids if needed, but as this is Tech section I'm not allowed, so I won't Quote Link to comment Share on other sites More sharing options...
colsoop Posted November 9, 2006 Share Posted November 9, 2006 Which bit do you mean Ro I think i have an old airbox lid knocking about if you like. Alternatively they are around £17 from Toyota if memory serves. Quote Link to comment Share on other sites More sharing options...
DamanC Posted November 9, 2006 Share Posted November 9, 2006 Sorry, i should have said "i super glued my clip back on" Quote Link to comment Share on other sites More sharing options...
JohnA Posted November 9, 2006 Share Posted November 9, 2006 Mine is busted too. Just drill a small hole and use a self-tapping screw to pull the two parts together. You only take the lid off once or twice a year, so no problem. Quote Link to comment Share on other sites More sharing options...
supRo Posted November 9, 2006 Author Share Posted November 9, 2006 Thanks - I was thinking a thin bolt so I can adjust the clamping pressure to suit? I've bought different screws, bolts and lots of differen clips from Wilko - I'll find the best method and return all the other bits Thanks guys Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 9, 2006 Share Posted November 9, 2006 I was going to say that I can supply new lids if needed, but as this is Tech section I'm not allowed, so I won't If the thread poster said "And does anyone sell new ones?" then you could swoop in like a vulture, but as they asked for fixing options you can't so there -Ian Quote Link to comment Share on other sites More sharing options...
supRo Posted November 12, 2006 Author Share Posted November 12, 2006 I just used one if these clips in the end, clamps together nicely . Just pushed it on. http://www.springmasters.com/sp/images/open-spring-clip.jpg Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 12, 2006 Share Posted November 12, 2006 I had this problem once, I think the new lid only from toyota was £16? Hardly worth the cable tie! Quote Link to comment Share on other sites More sharing options...
