Broken hinge on stock air box lid
supRo
I have aquired a stock TT air box. Sadly one of the plastic hinges on the lid is not there so won't be air tight around that area!
Options to fix:
1, drill a small hole on the casing (there is enough plastic to not drill right into airbox) and use a cable tie
2, Wilkos do assorted semi circular metal clips - one of them may stretch over the two parts and hold it tight
3, wrap tape around the whole air box!
4, other - please suggest!
Thank you,:)
Ro
I was going to say that I can supply new lids if needed, but as this is Tech section I'm not allowed, so I won't
:taped: :dontfeedmods: :)
If the thread poster said "And does anyone sell new ones?" then you could swoop in like a vulture, but as they asked for fixing options you can't so there :p
-Ian
