Justin Posted November 8, 2006 Share Posted November 8, 2006 I want to 'T' into my tranny fluid oil line to fit a temp sensor. Anybody able to point me at a web page or at least name the propper tools that I can use to close off the feed at two points so that I can cut it between and not lose shed loads of fluid? Thanks Justin Link to comment Share on other sites More sharing options...
alan_blue Posted November 8, 2006 Share Posted November 8, 2006 you wont loose loads of oil mate asi only residual will be in the lines, just remove and tilt them upwards and stow. but if you want to do a proper job you can get hose clamps in most places Link to comment Share on other sites More sharing options...
Justin Posted November 8, 2006 Author Share Posted November 8, 2006 OK ta for that good to know. Link to comment Share on other sites More sharing options...
TrickTT Posted November 9, 2006 Share Posted November 9, 2006 10mm copper pipe and compression fittings, available from B&Q or any plumbing shop are ideal for moving/extending tranny cooler pipes Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 9, 2006 Share Posted November 9, 2006 Copper will work harden with vibration, get Kunifer tubing from a commercial vehicle motor factors, that is what they use for brake pipes, et cetera, it's designed NOT to work harden and crack. Link to comment Share on other sites More sharing options...
