MarkR Posted November 8, 2006 Share Posted November 8, 2006 Hey everyone Has anyone else got this Boost Controller? I had mine fitted yesterday and the clicking noise from it is unbelievable I'm also not sure that the boost controller is working, as i still get 1.27 bar when i set it to "off" except minus the clicking. Any ideas? Cheers..... Quote Link to comment Share on other sites More sharing options...
nige Posted November 8, 2006 Share Posted November 8, 2006 do you have it set to auto? if so it wont work properly,it should not be clicking either. Quote Link to comment Share on other sites More sharing options...
MarkR Posted November 9, 2006 Author Share Posted November 9, 2006 Well, i had it fitted by a reputable company, but they hadn't fitted the Blitz SBC-ID before, and when i read through the manual, they had set it to auto with boost at 1.1 and a gain of 60(!!!) After reading the manual and adjusting the settings myself, i've now tried it on: CH1 set 10 gain 5 CH2 set 20 gain 10 Not sure if it's making a difference as the roads have been pretty busy and i haven't been able to open her up yet. The clicking noise is still there. I found a few articles on other forums for supras and other vehicles and a few people have had similar clicking issues. I was wondering if it was normal or if the solenoid needs replacing. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 9, 2006 Share Posted November 9, 2006 Actually EBC's do make a loud clicking noise when they are working...the closer to the cabin it's fitted the worse it is...I'd relocate it. Boost controllers can only raise boost. If you're seeing 1.27bar without it on A) you didn't need it B) you have a fully decatted exhaust and no restrictor ring leading to over boosting. 1) Move the solenoid pack so it's less audiable. 2) Search on here about restrictor rings and then get one fitted. Quote Link to comment Share on other sites More sharing options...
MarkR Posted November 9, 2006 Author Share Posted November 9, 2006 Cheers Alex I still have my front cat though. Should i still look at a restrictor ring? I've read about putting in stronger springs (not sure where but i think on the wastegate) to keep the boost down. Any ideas on this? I might try some sound deadening material first before moving the solenoid pack (i have some dynamat lying around somewhere). Cheers Mark Quote Link to comment Share on other sites More sharing options...
Guest Bijal Posted November 9, 2006 Share Posted November 9, 2006 seems to be plummed incorrectly OR the actual unit IS working but setup incorectly. give me a call, i will guide you through it if you like. bijal Quote Link to comment Share on other sites More sharing options...
Guest Bijal Posted November 9, 2006 Share Posted November 9, 2006 acualy just noticed you said it overboost even when you switcht he unit OFF, in that case A: r u sure the unit IS in "Off" possition. B: if yes to the above then its seems to be a hose not plumed in correctly, but then if thats the case it shouldnt being seing that much boost anyway? still, call me if your not sure. bijal Quote Link to comment Share on other sites More sharing options...
nige Posted November 10, 2006 Share Posted November 10, 2006 Set everything to manual,set gain to 12,and boost to 50, you should be hitting about1.1/1.12 bar, I still have the first cat in too and my boost is set to 52 and in this cold weather i'am peaking at 1.19 bar hope this helps. Quote Link to comment Share on other sites More sharing options...
supra_surj Posted November 10, 2006 Share Posted November 10, 2006 Hi mate ive had the same clicking from my boost controller. never really pay attention but it is loud. it already came on the car so i havent got any manuals so dont realy know where to set it. anyone got a manual for these? Quote Link to comment Share on other sites More sharing options...
Supragaz Posted November 10, 2006 Share Posted November 10, 2006 While on the ssubject of giving out Boost Controller advice. Anyone with an idea how to use the Blitz Dual SBC controller? Sorry for the Hijack Quote Link to comment Share on other sites More sharing options...
MarkR Posted November 22, 2006 Author Share Posted November 22, 2006 Hi guys Here's an update: I've booked my car in this weekend to have this checked out, cos when my BC is set to manual and "set=1" "gain=1" I'm hitting 1.55 bar at half throttle... i'm too scared to drive fast I leave the boost controller on to take advantage of the limiter function which i've set to 1.2bar and a reduction of 40% I want the garage to take the boost controller out of the equation and plumb it all back to standard and then do a boost reading to see if it's the Boost controller or something else. Any other ideas? Cheers Quote Link to comment Share on other sites More sharing options...
