SupraStar 3000 Posted November 8, 2006 Share Posted November 8, 2006 Fittings Jons lights and like a numpty I have unpluged the plugs and the harness from both lights which I have keeped apart (left and right set) DOH!! problem is, with the bulbs in the carrier plug I have no idea which is which because both fit in the same holes on the light. The small light is easy as it has the locking bar and extension for the side light. Its the large light and the middle light that I have mixed up. One plug is black, the other is brown. Both plugs have simular holders and both fit into each hole Any idea which is which? Cheers Ed Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 8, 2006 Share Posted November 8, 2006 IIRC the brown is the main beam, and the black is high beam. Easy enough to check though. Just plug 'em in, and turn 'em on Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted November 8, 2006 Author Share Posted November 8, 2006 so like this then Quote Link to comment Share on other sites More sharing options...
