Guest steveng Posted May 7, 2004 Share Posted May 7, 2004 Hi, Going to see a 6 speed TT N reg with 80K. Any pointers to look out for. Load whistle from turbos ? Knackered. How much to fix? Common problems that might be hidden from me. Any help appreciated. Cheers Gordon. Link to comment Share on other sites More sharing options...
AJI Posted May 7, 2004 Share Posted May 7, 2004 Yeah you pointed out the obvious ones like excessive noise from turbos. They should whistle but not scream at you. Also look out for modifications to the car, if they state its standard then make sure it is standard. Any problems caused by aftermarket parts may be troublesome to fix. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted May 7, 2004 Share Posted May 7, 2004 on the same hand dont be put off by aftermarket parts, if hes honest and has reciepts for the installation. If the guy is honest with you, like mine was he told me front bumper was resprayed when he glanced a wall in a multistory car park, then you can be pretty sure it is all done correctly Make sure all gears are used when driving, wiggle the car from side to side when driving Make sure you do a full lock turn in reverse and forward (important to listen for crunching noises) dont know bout the turbo's ddont have any press all buttons i didnt try the electric wing mirrors and only one moves check for spare wheel and tool kit, have a quick look under car for dents and that everything looks ok, check where car was parked for oil marks on road. all can think of on top of head people must hate me when coming to buy a car Link to comment Share on other sites More sharing options...
Getrag Posted May 7, 2004 Share Posted May 7, 2004 Lots of good advice in the second half of this page: http://i-supra.com/eve/ubb.x?a=tpc&s=154607117&f=9126041111&m=4286053631 Link to comment Share on other sites More sharing options...
albundy68 Posted May 7, 2004 Share Posted May 7, 2004 Go with your gut! if it dont feel right dont get it! And dont crash it! Link to comment Share on other sites More sharing options...
sinbad Posted May 7, 2004 Share Posted May 7, 2004 Let it idle for 5 mins and keep an eye out for oily smelling smoke. Link to comment Share on other sites More sharing options...
Guest steveng Posted May 7, 2004 Share Posted May 7, 2004 Cheers Hopefully by tonight i will be the proud owner of a 6 speed TT supra. The one im going to see is in the autotrader for £9250ono in Hamilton. Black standard car, anyone know it?. Cheers Gordon. Link to comment Share on other sites More sharing options...
Tom Posted May 7, 2004 Share Posted May 7, 2004 Originally posted by sinbad Let it idle for 5 mins and keep an eye out for oily smelling smoke. Yep thats the biggy! have a search for 'turbo seals' should bring up all the relevent info. Link to comment Share on other sites More sharing options...
matt Posted May 7, 2004 Share Posted May 7, 2004 Take the rad cap off and check that it has coolant , preferably red Take the oil filler cap off ..... should be gunge free and not burnt smelling Look at the IC , check for corrosion and damaged fins Check the rad for the same.... If its a UK check for oil leaks from the diff cooler/pipes Check Vin plate axle code...... if it ends in b it has an lsd Link to comment Share on other sites More sharing options...
toyotasuprauk Posted May 7, 2004 Share Posted May 7, 2004 All that and check if the air con works. Often missed on cold days. Not that its the end of the world if its doesnt but good excuse to knock off a few £'s. Gut feeling and if you like it make a big difference too:D Link to comment Share on other sites More sharing options...
womble Posted May 7, 2004 Share Posted May 7, 2004 Check the intercooler !!. It's on the drivers side behind the front inicator, give it a gentle prod and see if it falls apart as there are plenty of knackered (uk mainly) ones around now and a replacement is around £600, with summer coming you need it to be in good nick to help keep the charge cool. Link to comment Share on other sites More sharing options...
Guest steveng Posted May 9, 2004 Share Posted May 9, 2004 Thanks for the advice guys, bought the supra for a good price. Checked the turbos for blue smoke,all okay.Checked for damage engine and bodywork all okay, HPI ok. Car needed one new rear tyre and had a hole in the exhaust a blittz i think middle pipe. Needs timing belt done at 80K and alloys refurbished. Engine runs sweet as a nut, gearbox fine but need to get tracking done. Saying all that i got myself a standard 6speed dark blue TT for 8K, that must be the deal of the century. Guy was skint and didnt have the cash to fix up, didnt even clean the bloody car. Gutted it this weekend and gave it a good autogleem polish and it has come up a treat. Going to change everything that needs done before any mods. Are bilstiens shocks standard, also car is so low i keep hitting the cat exhaust of my drive way. Cheers Gordon :flame Dev Link to comment Share on other sites More sharing options...
Getrag Posted May 9, 2004 Share Posted May 9, 2004 Well done on the purchase, you must be so pleased, like this ----> Now get some pics up of the beast. I dont think those are standard shocks btw. Link to comment Share on other sites More sharing options...
womble Posted May 9, 2004 Share Posted May 9, 2004 Good on ya budy, sounds like you got as really good deal there as U.K manuals are few and far between. Not all that suprised to hear it came up well with a bit of elbow grease as these are really well put together / finished cars. Did you get a chance to check the intercooler as like I said alot of the U.k ones are pretty well knacked now (mines like a Cadburys flake ) and it's the last thing you need on a turbo'd car when the temps rise. From what you've been told by the previous owner and read on here what extras / mods do you think it has ?. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted May 9, 2004 Share Posted May 9, 2004 Well done on your purchase. Sounds like you got it for a good price too which is always a bonus. Enjoy:cool: Link to comment Share on other sites More sharing options...
Grazer Posted May 10, 2004 Share Posted May 10, 2004 Well done & welcome m8 Where u from? There's a few guys from up here on this board. Our next get together is going to be the Scooby run on June 6th. Click here for details. I thought Billstein shocks were standard - they're on mine too Link to comment Share on other sites More sharing options...
