My BL T67dbb single turbo install project
Homer
  • Replies 201
Posted Images
Gutted to hear your conversions coming to a bit of a halt mate :(
Guess was lucky that i got a t4 spacer with the kit i bought, and the screamer pipe is a different one, made for the xs manifold, comes out next to the downpipe, going in the same direction.
My blow off valve is going to go next to the intake of the cooler, not got anywhere else i can put i really :blink:
Daryll did you speak yo my man about doing the work??
Yeah I spoke to him but he really didn't seem interested in taking it on, he said drop the bits by and he'd do them when he had time. Found another guy who's a little more local, Roger Clark, he's doing all the work now.
HOMER i have a t67 fitted onto a xs power manifold. the turbo fitted straight onto the manifold with plenty of clearance and no issues. i had to cut the downpipe and reshape it then welded it back on, also i just cut the screamer pipe short to clear it from hitting .
What turbo is it Abs? Precision? I know that the precision ones don't always fit due to the compressor housing size on that side.
I could have cut the screamer pipe short but don't want the exhuast gases pointing directly into the subframe (and hence back up into the engine bay and potentially cabin, I'd rather they exit the engine bay cleanly. Its a simple job to have it adjusted so had that done while the other bits are modified.
Darryl, i thought i told you mine is a BL71 precision turbo too. The problem with yours i would imagine is that you already have an elbow welded on to it which limits your orientation of the compressor housing. I orientated my turbo and then had the elbow welded on to suit. Twist the housing round some more and it will fit but you may have to have the elbow recut and welded
Do you mean to rotate the compressor housing or the cartridge & housing?
With the locatation of the bolts on compressor it would mean rotating around 60deg, with the outlet pointing up towards the bonnet. If I rotate the cartridge the oil feed and water feed/return lines are going to be at 40deg angles. I thought this wasn't a good thing to do?
pm sent
Made some great progress today in getting things ready for the build next week.
First of all thanks to LeeT and especially Terribleturnber for their advice on the turbo install. I made a schoolboy error when test fitting the turbo the first time which resulted in me thinking the compressor housing would foul on the runner. For some reason I assumed the bolts on the back were in a fixed position :confused:
Now that I know how to rotate the housing the turbo fits perfectly without the need for a spacer :nana:
http://img156.imageshack.us/img156/1977/fourm23ox2.th.jpg
http://img231.imageshack.us/img231/764/froum24bw1.th.jpg
As the exhaust and screamer pipe are away being working on I can't go ahead and install the manifold yet (Was toying with installing the manifold and wastegate without the screamer pipe but apparently the pipe is a nightmare to install from underneath)
So instead, did some of the other jobs needed before the manifold goes on.
First up today was to install the wastegate. I needed to get this out of the way so I can work were the water return line needs to go (see next post).
Before the wastegate can be fixed to the manifold there are 3 fittings which need to be installed:
http://img293.imageshack.us/img293/1853/forum26bq0.th.jpg
http://img293.imageshack.us/img293/1687/forum27kg2.th.jpg
Next is to fit the wastegate to the manifold. A pic of the parts required:
http://img276.imageshack.us/img276/7906/forum25gh3.th.jpg
I used the gasket that came with the xs power kit but used a thin layer of firegum to ensure a good seal.
The valve needs to be compressed slightly in order to fit the wastegate to the manifold, however the spring is very strong so you won't be able to compress it and bolt it up at the same time. Also, due to the spring washers there wasn't enough thread to get the nut on without the valve being compressed, so I fitted it in two stages: first bolted up two bolts without any washer to compress the valve, this then allows enough thread to put the other two spring washers on and tighten up.
http://img293.imageshack.us/img293/1484/image27ua8.th.jpg
Then remove the first two nuts and refit with the washers. The wastegate is now fitted:
http://img144.imageshack.us/img144/7739/image28jy8.th.jpg
A test fit shows that the wastegate fitted fine and (though very close) does not touch the engine block. The two fittings on the wastegate did need their position adjusting so they were pointing in the right direction.
One thing that needs to go in before the manifold is the water return for the turbo. This is only required for water cooled turbo's, those without water cooling usually just block these two pipes off.
The pic below shows the two feed lines from the water pipe. #1 is the feed for tubbie 1, #2, for tubbie 2.
http://img293.imageshack.us/img293/7412/forum29tj8.th.jpg
There's various opinions on how best to plumb the water lines, here's the main ones I know of:
1) Use #2 as the return, #1 as the feed.
2) Block #2 and use #1 as the feed;
3) Route both #1 and #2 together and use 1 T-piece for the feed
My original plan was going to use option 1 as the turbo mounting position on the xs power manifold tends to block the path for using returns from the water elbow (stock return position)
However, Terribleturner had water temp issues with this setup so I started looking for other options. Ian C recommended option 3 which more closely replicates the stock system (i.e. allows greater water flow than option 2, therefore maybe less water temp problems). Ian has used this setup to great success so I thought best to follow suit :)
Next you can see the -8 hose plumbed in, the T-piece is where the feed from the turbo will be fixed. I can't fit this pipe and fitting yet as I managed to order a wrong adaptor last week (doh!!).
The pipe has to be routed out of the way of the wastegate so found it best to go below the engine mount, this route will also keep the pipe away from the very hot exhuast runners. It's secured using just one hose clip which is attached to the mounting point for one of the stock turbo support bars.
http://img501.imageshack.us/img501/9324/forum30ag4.th.jpg
I won't be able to do more to the water return or feeds until the manifold and turbo are fitted.
During the strip down I ended up having to cut off most of the stock hoses, they were so brittle most split before making any attempt to come off! This included the main water feed from the water pump to the heater matrix. Rather than replace with large braided hose (which won't manage the tight angles) I used new stock hoses. Here's the two pipes that need to be connected:
http://img390.imageshack.us/img390/8461/forum31ww2.th.jpg
There is a water pipe which is normally bolted to the back of the tubbie #2 which can be reused. It has a couple of brackets on it which (mostly for tidiness) need to be removed. As usual the mini grinder does the job
http://img155.imageshack.us/img155/6416/forum32mx4.th.jpg
Now installed along with the new hose, I may trim this down a little later on:
http://img61.imageshack.us/img61/2680/forum33gv9.th.jpg
The canister and EVAP system I believe can be retained, but I can't be bothered with the effort, plus its extra clutter (and weight).
First off is to remove the pipe that used to feed into the intake for tubbie #1:
http://img392.imageshack.us/img392/4029/forum34fy5.th.jpg
http://img392.imageshack.us/img392/3456/forum35kj6.th.jpg
The pipe is a bit of a fiddle to come out and it's necessary to bend it a little at the canister side, but it should pop out eventually.
http://img300.imageshack.us/img300/609/forum36wh5.th.jpg
Now the vapour hose from the fuel tank can be removed (you'll know when this one comes out as it stinks of petrol).
http://img381.imageshack.us/img381/1864/forum37wa2.th.jpg
Next the hose from the pressure tank and throttle body can be removed. There is a rubber pipe that slots into a hardpipe just behind the fpr in this pic. Sorry for the poor quality.
http://img361.imageshack.us/img361/8806/forum38zv5.th.jpg
This picture shows the other end of the hardpipe and the way it T's off into the pressure tank and throttle body.
http://img297.imageshack.us/img297/7072/forum39mz1.th.jpg
Unscrew the two bolts that hold the hardpipe to the manifold (forgot to get a pic of them), remove the diagnostics ports (it simply unclips) and pull off the blue valve and pipe to the pressure tank. It should look like this once removed:
http://img150.imageshack.us/img150/5672/forum40ie7.th.jpg
For now I've blocked off the pipe from the throttle body with a screw, the pipe to the pressure tank is left open as it's now redundant. (again, sorry for the poor pic)
http://img150.imageshack.us/img150/9299/forum41bu3.th.jpg
Now the charcoal canister can be removed, simply undo the two bolts and it will lift out.
http://img280.imageshack.us/img280/6121/forum43kt0.th.jpg
I wanted to retain the mounting point for the diagnostics port so had to cut up the tube shown 3 pics above. The end of the tube is also removed (see next paragraph)
http://img149.imageshack.us/img149/6461/forum42ky8.th.jpg
Diagnostics port mounting reinstalled:
http://img291.imageshack.us/img291/6112/forum44iu3.th.jpg
As mentioned earlier, the vent pipe from the fuel tank now needs to be plumbed back into the 'drain' pipe from the canister. This is where the hardpipe cut off earlier (two pics up) comes into use - insert one end into the rubber pipe, the other into the drain.
http://img329.imageshack.us/img329/4496/forum45ep9.th.jpg
That’s all for now. Just have to wait for parts before the final fit can begin (hopefully!)
