My BL T67dbb single turbo install project
Homer
Fun and games, eh Darryl. I know this is of no use, but it's a shame you're so far from me as i could get pretty much any fab work done for you at the engineering company i'm working for now. :(
You know it'll be worth the hassle in the end though.
  • Replies 201
Posted Images
Would it be out of order to say "buy a kit that fits"? - If so, I won't say it. ;)
I'm so glad we didn't have any of these problems when we did mine. The only bit of welding mine needed was a sensor bung.
It'll all be worth it in the end Darryl. Keep up the good work, and well done keeping patient! :respekt:
Is the XS kit not supra specific ? just wondering why all the fitment problems. My HKS kit fitted like a glove. But keep up the good work. I didnt have the balls or know-how to do my single conversion, so much easier for me to pay a garage a small fee instead :) SO kudos to you for taking the job on yourself.
Not at all :D
You wouldn't beleive the amount of times I've said that to myself the last 2 weeks! If only I'd bought that 2nd hand BL manifold from Col... :rolleyes:
Th XS Power kit is supra specific but its not very well made and has a mix and match of copied bits (mainly relating to the fact that the manifold is not clocked but the rest of the kit is designed for a clocked manifold)
Please point me in the direction of the garage that only wanted a small fee to do the work :)
Me too!! The chepeast were asking around £600 to do the install, but then charge a heck of a lot for fabrication and the 'extra' bits that tend to be cheap rubish. Despite the problems it's still going to be significantly cheaper than paying a professional to do it.
Do any of you guys plumb the exit off the gate back into the downpipe?? My kit will be setup like this I think?
As fair as I am aware most off the shelf kits use a screamer but there are some serious noise advantages of going back into the downpipe.
The Greddy/HKS Manifolds and their copies are much much better. It's clear that the XS power kit is made by someone who isn't working to a well defined template or anyone with any level of Quality Control.
The kit that is spot on is only spot on out of sheer luck it seems. The USDM/JDM manifolds are much much more accurate well thought out. You pays your money...
As in loudness or quietning it down a fair bit, mine will be setup on a cast manifold and I will need to fabricate wastegate fittings myself but am not keen on a screamer pipe!
It will be setup almost identicals to Simon B when its finished
Lets hope it lasts too ;)
True especially if you havn't seen the fabricators work.
Definatly, i bet the jog moved a while ago and he hasn't noticed and keeps churning out the manifolds with the angle wrong.
I wish I was a rich person that considered £600 small change :(
If Darryl clocks up the amount of hours he's put into this install, then times that by his hourly rate he's paid by his boss, then adds the £220 fab costs, I'd wager that £600 for an install is cheap. Doesn't Pheonix charge £800? Then you've got fuel management & mapping....
Finally got the manifold back from the fabricators :)
The wastegate pipe has been chopped a few mm and turned a few degrees, this will bring the wastegate slightly away from the block and stop it, and the brass fitment, touching it.
http://img174.imageshack.us/img174/1958/forum46uv0.th.jpg
This image shows where the cut and weld was made. The welding I'm getting done is rather beter quality than the one that made the manifold ;)
http://img174.imageshack.us/img174/6467/forum47oe6.th.jpg
