HID part2
paul_y3k
ok given my last abortive attempt I'm going to try again to get a set of HID to fit.
Now I'm most likely to go back to the ebay store - xenon direct and this time i'll be buying a bulb of 9005.
anything else to do / check before i spend ? I really dont fancy having more problems yet again ......
9005 bulb is the correct model you need, you will also need to confirm what Kelvin rating you want the bulbs, eg. 4200K, 6000K etc. Make sure you get the correct bulbs for the ballasts you have, some ballast specs vary, so you need to match the brand of bulbs with the ballasts.
Can you not swap the bulbs you got for the correct type?
