Homer Posted November 5, 2006 Share Posted November 5, 2006 Just spent the last 4 hours trying to remove 3 nuts!! Its the 3 lower ones than hold the turbo's to the manifold (1 on front tubbie, 2 on rear), but they just will not move... There's not enough room to get a socket on them so have to use a spanner, but with that I can't get enough leverage. Tried heating them too but that didn't help. Any ideas?? Quote Link to comment Share on other sites More sharing options...
Robert Posted November 5, 2006 Share Posted November 5, 2006 ah mate, i spent days and days on these bloddy nuts, heat didn't work,i gave up and sent the car to turbofit Quote Link to comment Share on other sites More sharing options...
colsoop Posted November 5, 2006 Share Posted November 5, 2006 What pentrating fluid are you using ? Quote Link to comment Share on other sites More sharing options...
Ian R Posted November 5, 2006 Share Posted November 5, 2006 What pentrating fluid are you using ? KY jelly ??? Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted November 5, 2006 Share Posted November 5, 2006 i had the exact same issue, i was flying at the removal of the old stuff and thinking well whats everyones problem with removing it, as had most of it out in 2hours, then came down to them 3 bloody nuts, and cue another 4 hours eventually found a way of getting them off, Quote Link to comment Share on other sites More sharing options...
Homer Posted November 5, 2006 Author Share Posted November 5, 2006 What pentrating fluid are you using ? WD40 and a heck of a lot of it. Been spraying the bolts regularly since yesterday morning in preperation. Emin... do tell, how did you manage it in the end? Quote Link to comment Share on other sites More sharing options...
Tom Posted November 5, 2006 Share Posted November 5, 2006 try to get something that you can put over the spanner for leaverage such as a long hollow bit of metal, this should work. make sure your using the closed part of the spanner on the nut, Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted November 5, 2006 Share Posted November 5, 2006 well with all the other bolts i just managed to undo them with a slight wack of a mallet but as you say cant hardly get any movement for those 3 so applied lots of wd40 and cut down a spanner then used a bar from a socket set with a socket on the end of it that fitted tightly over the spanner cut end and then just undid it, make sense?lol Quote Link to comment Share on other sites More sharing options...
Homer Posted November 5, 2006 Author Share Posted November 5, 2006 Emin, thanks yes I know what you mean. Didn't cross my mind to try that. The spanner on spanner method didn't work due to lack of space. Will give that a try tomorrow (yet ANOTHER walk to the local Haflords, 2 miles away!!) after I've bought a spare 14mm spanner to kill. Even got as far as getting the mini grinder out, but even that wouldn't fit in the space available! Quote Link to comment Share on other sites More sharing options...
Pig Posted November 5, 2006 Share Posted November 5, 2006 Coming soon: Boostlogic T67dbb Looks like not as soon as you would like with this problem though. Quote Link to comment Share on other sites More sharing options...
Rich Posted November 5, 2006 Share Posted November 5, 2006 use a proper penetrating fluid,if I remember rightly these were a pain in the arse ! Quote Link to comment Share on other sites More sharing options...
JohnA Posted November 5, 2006 Share Posted November 5, 2006 WD40 and a heck of a lot of it. Been spraying the bolts regularly since yesterday morning in preperation.? WD stands for Water Dispersant. It is a substandard penetrating fluid. PlusGas is better, you can find it at motor factors. Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 5, 2006 Share Posted November 5, 2006 quite sure i used a long reach 14mm spanner for these. Don't remember struggling too much either Quote Link to comment Share on other sites More sharing options...
Homer Posted November 5, 2006 Author Share Posted November 5, 2006 WD stands for Water Dispersant. It is a substandard penetrating fluid. PlusGas is better, you can find it at motor factors. I'll have a walk to a few tomorrow and see if its stocked. Last time I looked couldn't get plusgas anywhere around here. Lee, I think the key there is long reach... again no where local stocks long reach spanners. I'll give Emin's idea a try tomorrow (effectively makes a long reach spanner), if that doesnt solve it they're getting cut off Quote Link to comment Share on other sites More sharing options...
mr lover Posted November 5, 2006 Share Posted November 5, 2006 again no where local stocks long reach spanners. lee is local Quote Link to comment Share on other sites More sharing options...
Scooter Posted November 5, 2006 Share Posted November 5, 2006 Homer where are you based in Berks? Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 5, 2006 Share Posted November 5, 2006 lee is local Its actually quite a shame as i'm only down the road for work at Spencers wood tomorrow but i'll have a passenger who won't want to hang around whilst i remove the turbos for you:( Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 5, 2006 Share Posted November 5, 2006 Homer where are you based in Berks? Reading Quote Link to comment Share on other sites More sharing options...
mr lover Posted November 5, 2006 Share Posted November 5, 2006 he is in reading. touche Quote Link to comment Share on other sites More sharing options...
Scooter Posted November 5, 2006 Share Posted November 5, 2006 ta its just i have one of these and thought it might be ideal? 14mm podger spanner Quote Link to comment Share on other sites More sharing options...
Marty Posted November 5, 2006 Share Posted November 5, 2006 Fun removing them isnt it You need to try to shock the spanner when its on the nut mate Quote Link to comment Share on other sites More sharing options...
Homer Posted November 6, 2006 Author Share Posted November 6, 2006 Finally removed them after another 2 hours today. What an absolute ar$e of a job! Cheers everyone for the advice, Emins way worked in the end. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 6, 2006 Share Posted November 6, 2006 WD stands for Water Dispersant. Water Displacement, actually. Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted November 6, 2006 Share Posted November 6, 2006 ah glad it worked! Quote Link to comment Share on other sites More sharing options...
Wez Posted November 6, 2006 Share Posted November 6, 2006 Not a nice job, well done Quote Link to comment Share on other sites More sharing options...
