Nic Posted August 6, 2001 Share Posted August 6, 2001 I've just bought a set of HKS Cams (i256/e264) and HKS Pulleys from Justin, can anyone explain in simple step by step instructions how to set up the timing once they are fitted please. cheers Nic Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted August 7, 2001 Share Posted August 7, 2001 As the HKS cams can be used with the stock pulleys, in very simple terms, you should set them to the zero mark on the pulley. yours, J Quote Link to comment Share on other sites More sharing options...
Nic Posted August 7, 2001 Author Share Posted August 7, 2001 Thanks J So all should be fine at zero even with the 264exhaust cam? cheers Nic Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted August 7, 2001 Share Posted August 7, 2001 Yes, as I say the HKS cams can be used with the stock pulleys so the zero setting should be fine. That's where I set mine when I had the HKS cams. I played around with the 256's and the 264's in various combinations. Yours, J Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 22, 2001 Share Posted August 22, 2001 So whats the point in getting adjustable cam gears then? Or are these only needed for 272's? Quote Link to comment Share on other sites More sharing options...
Rich J Posted August 22, 2001 Share Posted August 22, 2001 Quote: from Paul Whiffin on 12:45 am on Aug. 23, 2001[br]So whats the point in getting adjustable cam gears then? Or are these only needed for 272's? I think it's so the cam timings can be set-up on a dyno to get the best out of other mods you have done. Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted August 23, 2001 Share Posted August 23, 2001 The cams come with a graph of optimum settings that HKS claim they have determined from their tests. In order to set the cams to these HKS determined optimum settings, it is necessary that you fit the adjustable cam pulleys. However, HKS state that the cams are designed to be used with the stock pulleys also. Yours, J Quote Link to comment Share on other sites More sharing options...
