GOGS Posted November 3, 2006 Share Posted November 3, 2006 getting a knocking noise from the front end of the car. at motorways speeds or smooth roads, its great not a peep, but going over bumpy roads or even just a single pot hole it rattles its head off. any one else had this problem? Link to comment Share on other sites More sharing options...
Underworld Posted November 3, 2006 Share Posted November 3, 2006 I hear its good to check that the nuts are tightened up correctly. For some reason I cant copy and paste a link nor can i right click paste lol. Goto the technical reference and faqs, theres an article on there Link to comment Share on other sites More sharing options...
SilverSoop Posted November 3, 2006 Share Posted November 3, 2006 it could well be your cv joint or your cv boot knocking, does it do it when you turn aswell, left and right?? Silver 94 J-spec n/a 18'' Gewalt gold racing alloys Lowered Limited slip diff Blitz nur spec cat back HKS front pipe 2nd cat removed and as noisy as hell!! And lots more to come........ Link to comment Share on other sites More sharing options...
Homer Posted November 3, 2006 Share Posted November 3, 2006 Check the sub frame bolts are torqued up correctly, also check the conditions of the drop links. Failing that it could well be a faulty damper. Silversoop, it can't be CV joints if the knocking is from the front. Link to comment Share on other sites More sharing options...
GOGS Posted November 4, 2006 Author Share Posted November 4, 2006 everything has been tightened up. got it checked out on wednesday/thursday, cant remember lol. the guy that had a look at it is a toyota specialist. he reckoned that supra's are bad for ball joint but he can only check it if he strips it apart. it doesnt do it on motorways, but only bumpy roads. it just does it randomly. i can drive at 10mph, turn a corner and it wont do it. i could drive at 30mph turn a corner and it clunks. its starting to annoy the hell outta me. just hoping someone else has had a similar fault and know what it may be Link to comment Share on other sites More sharing options...
