j19edg Posted November 3, 2006 Share Posted November 3, 2006 Just Been Looking On The Piston Head Site And A Thread At V Max And It Says A Tt Supra Did A Run And It Topped Out At 170 He Says It Had A Limiter On At 170 Is That Right? I Thought Limiters Were At About 111 And Then Sky's The Limit.... Quote Link to comment Share on other sites More sharing options...
miko_supra Posted November 3, 2006 Share Posted November 3, 2006 yeah shouldnt have any other limit than 112 Quote Link to comment Share on other sites More sharing options...
Gazboy Posted November 3, 2006 Share Posted November 3, 2006 Just Been Looking On The Piston Head Site And A Thread At V Max And It Says A Tt Supra Did A Run And It Topped Out At 170 He Says It Had A Limiter On At 170 Is That Right? I Thought Limiters Were At About 111 And Then Sky's The Limit.... So what are you saying? That after spending £150 gate money, £100 fuel, and shagging a set of pads he decided not to max out his car? Quote Link to comment Share on other sites More sharing options...
j19edg Posted November 3, 2006 Author Share Posted November 3, 2006 No Not Saying He Has Not Maxed Out His Car To The Limit He Was Saying He Hit A Limiter Stopping Him Goin Any Faster Quote Link to comment Share on other sites More sharing options...
The Restorer Posted November 3, 2006 Share Posted November 3, 2006 TC fuse limits you to 155mphish... 170 on the Speedo! Moaeed Quote Link to comment Share on other sites More sharing options...
Gazboy Posted November 3, 2006 Share Posted November 3, 2006 No Not Saying He Has Not Maxed Out His Car To The Limit He Was Saying He Hit A Limiter Stopping Him Goin Any Faster Then maybe there is a speed limiter up there somewhere... If you are limited to 180kph, and your speedo reads in kph, when you change the readings to mph, you may be limited to 180mph on the clocks? A genuine 170 would show up at 180mph on the clocks would it not? Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 3, 2006 Share Posted November 3, 2006 If you are limited to 180kph, and your speedo reads in kph, when you change the readings to mph, you may be limited to 180mph on the clocks? A genuine 170 would show up at 180mph on the clocks would it not? Yes, some cheapo type converters just divide the entire speed signal by 5/8ths to get a MPH reading. In effect, that will give you a limiter at around 180mph. The better ones, like the Thor ones, actually cap the speed signal at around 100mph, so, although the car can increase in speed, the ECU never 'sees' any more than 100mph, thus totally removing the limiter. I've seen way more than 170mph via GPS. Speedo needle pointing just to the left of straight down. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 3, 2006 Share Posted November 3, 2006 TC fuse limits you to 155mphish... 170 on the Speedo! MoaeedOnly on UK/USA spec Supras Quote Link to comment Share on other sites More sharing options...
Jake Posted November 3, 2006 Share Posted November 3, 2006 I've seen 172mph (GPS) in my J-spec BPU Supra. Speed was was still climbing slowly but not enough clear road to keep going. Quote Link to comment Share on other sites More sharing options...
