paul_y3k Posted November 2, 2006 Share Posted November 2, 2006 I've just bought a HID (6K) kit from xenon direct via ebay. I've seen a few other people that have used them and were chuffed with the results so i thought why not and ordered a set. the bulb size I ordered was 9006 - which is the same size as those that are in the car at the moment (jspec TT aerotop). The kit looks great, but I just cannot get the bulb to position correcty. I'm sat here now, the front light out on the table, and I'm struggling. Should I start shaving the tabs and the mount to get it to fit, or push it harder ? Have I dropped a clanger and bought the wrong kit ? Help guys ! pleaaase. and if anyone is in ipswich that wants a cup of tea and to give me a hand please do ! Quote Link to comment Share on other sites More sharing options...
Nic Posted November 2, 2006 Share Posted November 2, 2006 9006 bulbs won't fit in the J-spec headlights, you need 9005 bulbs. Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 2, 2006 Share Posted November 2, 2006 9005 for J spec. Is it a UK suplier??? Give them a call and plead insanity Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 but the halfords 9006 do ? it listed 9006 as dipped and 9005 as main beam Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 2, 2006 Share Posted November 2, 2006 9006 is listed for UK spec cars for dipped beam, different to J Spec as the glass headlights are different than J Spec plastic ones. Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 it listed 9006 as dipped and 9005 as main beam Them would be for Uk headlights i believe. I think im right in saying your HID's would fit a pair of Uk headlights! Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 ok so why do the 9006 that are in there now fit fine. ? do i have to admit defeat or can I modify the tabs to get to fit then ? Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 9006's are to fat around the rubber collar to fit in, you need the thinner 9005's Quote Link to comment Share on other sites More sharing options...
milocoon Posted November 2, 2006 Share Posted November 2, 2006 Been covered before but you do not have 9006 you have 9006J instead, a suitable replacement is a 9005. 9006J only available in JAPAN ! Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 ok so why do the 9006 that are in there now fit fine. ? do i have to admit defeat or can I modify the tabs to get to fit then ? I cant understand why the 9006 bulbs you have fit, maybe they have been shaved around the collar? edit: oh if they are 9006J then they should fit, although Jpn only as posted above! Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 collar ? as in the bits with the tab's ? Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 collar ? as in the bits with the tab's ? Erm its around the rubber bit at the base of the bulb, not where it connects to the loom! Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 The reason they wont fit is because you cant push them far enough into the housing to turn! I dont think they can be modified to fit, the best option is to get a set of Uk headlight, im pretty much 100%sure they would fit the dipped headlight spot on a set of those no modifications needed! Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 sooooooo five minutes with a file ? Quote Link to comment Share on other sites More sharing options...
Fifty Posted November 2, 2006 Share Posted November 2, 2006 Paul nope its the diameter of the centre around the bulb base its 22mm instead of 20mm as in the 9005. I know cos I just got stuffed buying 9006 by mistake. Even with the 9005 had to dremel down 2 of the lugs and remove the 2 slots in the harness clip! I do now have considerably better dipped lights though Rich:d Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 Paul nope its the diameter of the centre around the bulb base its 22mm instead of 20mm as in the 9005. Yep thats it! Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 hmmmmm so in theory o should be able to file it down ? or shall i just give up Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 hmmmmm so in theory o should be able to file it down ? or shall i just give up I guess in theory you could file it down, but if you do it wrong it wont fit Uk or J-spec youll be left with a nothing fitment! Quote Link to comment Share on other sites More sharing options...
Fifty Posted November 2, 2006 Share Posted November 2, 2006 Dont think you should file it because it has a rubber ring round it if you file it this wont fit and your lights will fill up with water? Rich:d Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 yeah i guess :S really miffed now. Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 maybe an exscuse to buy some uk spec lenses then ? lol Quote Link to comment Share on other sites More sharing options...
Fifty Posted November 2, 2006 Share Posted November 2, 2006 precisely I have kept my 9006 for when I do that Rich Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 maybe an exscuse to buy some uk spec lenses then ? lol Yep or sell your HID kit to a Uk spec owner and buy the 9005 kit! Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted November 2, 2006 Author Share Posted November 2, 2006 ok guys. well thanks for all the advice. I shall go put the car back togehter with the mysteryiouse fitting halfords 9006 bulbs and then go cry ... alot Quote Link to comment Share on other sites More sharing options...
Rayman Posted November 2, 2006 Share Posted November 2, 2006 ok guys. well thanks for all the advice. I shall go put the car back togehter with the mysteryiouse fitting halfords 9006 bulbs and then go cry ... alot So they are not 9006J then? I dont understand how 9006 are in there, they shudnt fit, have they been modified or did you fit them yourself? Quote Link to comment Share on other sites More sharing options...
