Underworld Posted November 2, 2006 Share Posted November 2, 2006 Hi guys, I was just about to buy some el glo gauges to finish off my vehicccleee. Then I had a thought about my current gauges. At the mo they max out at 110mph, so ill probably need a convertor of some sort to put the el glo gauges on? Thanks! Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted November 2, 2006 Share Posted November 2, 2006 The el glo ones are from speedhut, this means they are custom made jobbies, if you want 110mph ones, ask for 110mph faces On the other hand, this may be a good time to get your supe de-restricted Quote Link to comment Share on other sites More sharing options...
Steviekid Posted November 2, 2006 Share Posted November 2, 2006 Yeah, might as well do both things when you've got the speedo out. It's a bit lame having a speedo that only goes up to 110mph anyway! Quote Link to comment Share on other sites More sharing options...
Underworld Posted November 2, 2006 Author Share Posted November 2, 2006 Im pretty sure it is deresricted but still has 110mph gauges! Quote Link to comment Share on other sites More sharing options...
Steviekid Posted November 2, 2006 Share Posted November 2, 2006 Im pretty sure it is deresricted Have you had the needle well beyond 110mph on the dial? Bear in mind that this will probably be reading a bit high so you might not hit the limiter until around 120mph on the speedo. Quote Link to comment Share on other sites More sharing options...
Underworld Posted November 2, 2006 Author Share Posted November 2, 2006 I think so ill have another check. Lets say it is delimited, ill probably have to get a thing to modify the needles movement so that it fits a normal mph gauge before i get the el glo :S Quote Link to comment Share on other sites More sharing options...
Stonkin Posted November 2, 2006 Share Posted November 2, 2006 You dont know if your supes delimited??? Man, your not driving it properly!!! Quote Link to comment Share on other sites More sharing options...
Underworld Posted November 2, 2006 Author Share Posted November 2, 2006 Lol im pretty sure it is. Ill have to test again ^^ By the way whats the gizmo that changes it from 110mph on the clock to read faster speeds? Quote Link to comment Share on other sites More sharing options...
