Anyone wanting a proper gearbox?
Chris Wilson
It's a totally different gear set to the Skyline R32 / R33 gear kit, in a totally different case. The Skyline Quaife kit uses the stock Nissan gear case, and with it it is limited to the small gear to gear centres. This box is Quaifes own casing, with much larger gear centres, and wider gears, unencumbered by making space for synchro mechanisms. No relationship to the Skyline gerar *KIT* at all. (4 WD Skylines are stuck with a casing that allows the mounting of the centre diff assembly).
