scotspower Posted November 1, 2006 Share Posted November 1, 2006 Can't seem to get definitive answer to this one, hopefully you guy's can help. Are all supra's pre wired for one of these if not how do i check to see if i have the wiring? Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 1, 2006 Share Posted November 1, 2006 No. Many seem to have the plug under the headlight on the drivers side, but it's rare that the ECU and switch wiring are present if the spoiler isn't. You'll need to remove the radio to find out. Link to comment Share on other sites More sharing options...
scotspower Posted November 1, 2006 Author Share Posted November 1, 2006 Should i be able to find the end of the wiring loom (if its there) under the drivers headlight, do i need to remove the headlight to check? Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 1, 2006 Share Posted November 1, 2006 You shouldn't need to. Just follow the loom down by the light and you should see a largish 4 pin plug not connected to anything. Link to comment Share on other sites More sharing options...
