Jim_1979 Posted November 4, 2006 Author Share Posted November 4, 2006 Its prob the cat temp sensor just cable tie it up out the way:) thanks Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 4, 2006 Author Share Posted November 4, 2006 Sounds like you've possibly got a replacement gasket for the 1st cat. The gaskets I have are silver and shaped like the exhaust flanges, with holes in for the bolts. Although you may have bought replacement gaskets for the original exhaust (no idea what it's like). In which case they are wrong. well I did order the parts which were on the exploded diagram of the exhaust system (from the toyota parts program thing). In the pictures, they all look like rings. 3 of 17451 What you described was what I was expecting, but they look like what they look like in the picture I've got. Also, the garage which got them for me didn't seem to think they were the wrong part? Possibly these are the stock toyota gaskets?? Link to comment Share on other sites More sharing options...
matt k Posted November 5, 2006 Share Posted November 5, 2006 Another quick question..... The cat closest to the engine seemed to have some sort of sensor plugged into it? I assume (havn't looked), that the decat will have the same space for the sensor?? Thanks!! Sounds like the O2 (lambda) sensor and the decat should have a flange for it to go back in. Link to comment Share on other sites More sharing options...
Steviekid Posted November 5, 2006 Share Posted November 5, 2006 Sounds like the O2 (lambda) sensor and the decat should have a flange for it to go back in. The O2 sensor in the J-spec goes into the exhaust manifold before the first cat. The sensor in the first cat is just a temperature sensor that isn't needed anymore with decats. Link to comment Share on other sites More sharing options...
Bob Posted November 5, 2006 Share Posted November 5, 2006 well I did order the parts which were on the exploded diagram of the exhaust system (from the toyota parts program thing). In the pictures, they all look like rings. 3 of 17451 What you described was what I was expecting, but they look like what they look like in the picture I've got. Also, the garage which got them for me didn't seem to think they were the wrong part? Possibly these are the stock toyota gaskets?? Yup, sounds like stock gaskets then mate. You need the aftermarket gaskets, unfortunately. 2 of them in total, and a tube of Firegum or similar exhaust sealant for the 1st cat. As I mentioned, Chris Wilson does the proper Trust gaskets. iirc they're about £8.50 each. Ask him nicely, he may throw in some bolts as well Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 5, 2006 Author Share Posted November 5, 2006 I'll see how I go with the toyota ones and firegum. If I can get the to stay in place when I put the exhaust together, it looks like they'll be fine. Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 5, 2006 Author Share Posted November 5, 2006 Well I gave up on the cat closest to the engine! Couldn't get it off at all!!?!..... Put the exhaust on with that cat still in place. Not noticed any performace difference than before and it doesn't hit fuel cut etc either. I take it this is the norm? I'll be taking it to an exhaust place this week to get that cat off! Link to comment Share on other sites More sharing options...
Steviekid Posted November 5, 2006 Share Posted November 5, 2006 I take it this is the norm? Yeah, the first cat is very restrictive. I got my studs out ok but one started going in slightly off thread when I put the decat in and it was a bastard to get it running straight again. Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 5, 2006 Author Share Posted November 5, 2006 it's a twat of a job to do!! If I knew how much hassle I would have happily paid someone/a garage to do it! Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 5, 2006 Author Share Posted November 5, 2006 Also, exhausts sound weird on an automatic car! Link to comment Share on other sites More sharing options...
Steviekid Posted November 5, 2006 Share Posted November 5, 2006 If you lived a bit further West I could have given you a hand! I've spend half the day trying to get my bloody gauges to light up again. Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 6, 2006 Author Share Posted November 6, 2006 took it to an exhaust place today. They got two of the bolts out from the cat, but not one. They soaked it in wd40 today and are going to try again tomorrow! Link to comment Share on other sites More sharing options...
Bob Posted November 7, 2006 Share Posted November 7, 2006 2' BREAKER BAR AND A UNIVERSAL JOINT!!! Off 1st time every time. Link to comment Share on other sites More sharing options...
Jim_1979 Posted November 7, 2006 Author Share Posted November 7, 2006 Well it's finally done!!.... Link to comment Share on other sites More sharing options...
