Fuel cut and missfire??
Scooby
A few weeks ago I fitted a boost controller to my UK spec TT.
Since then I have been getting a slight misfire under load but only in 4,5 or 6th gear. I thought it sounds like plugs failing and changed them but it is still there. Also when on full boost the I get the warning light flash up on the dash and loose all power for a couple of seconds.
Any ideas??
Could the FCD need adjusting??
